nyt nyt is offline
Car: 335ix
Default Anyone else experience BOV sound change after inlets? - 06-27-2015, 02:21 PM
So after installing vtt inlets, my BOV went from just a normal quiet wooshing sound, to something a bit different. The sound is definitely coming from the BOV, as it isn't there if I pinch off the vac hose going to it. I opened it up, yellow spring, no internal issues, moves easily.
Thoughts?
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 06-27-2015, 02:54 PM
Seems to be common. There is a post over on e90post with some vids as well.
http://www.e90post.com/forums/showthread.php?t=1143824
335is DCT
nyt nyt is offline
Car: 335ix
Default 06-27-2015, 04:23 PM
Thanks for the link. I hate it now Probably due to more volume of air or some resonance.
firemanjust1's Avatar
firemanjust1 firemanjust1 is offline
Car: 2008 BMW 335xi
Default 06-27-2015, 05:16 PM
I can tell you that I bought a bov and took it off immediately after inlets install and went back to just venting to atmosphere sounds much better imo .
JB4/G5 ISO ,AR DP,BMS DCI,NGK 5992 BMS Meth kit dual nozzle CM 7 & 5,VRSF 7 IC, Stett chargpipe, E60 mix, 255 Walbro, Bms Race flash. RB turbos , VTT inlets ,BMS OCC, 3.5 N20 sensor, Conti DWS
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 06-27-2015, 07:48 PM
Maybe it's just the tial? I have a turbosmart race port and inlets getting installed, will find out soon enough.
Stucks Stucks is offline
Default 06-27-2015, 09:26 PM
I have vtt inlets and a tial q bov, with the yellow spring in it. mine does not sound like that.
Current: 2008 e92 335i coupe.
nyt nyt is offline
Car: 335ix
Default 06-27-2015, 10:17 PM
how does it sound? Video?
Default 06-27-2015, 10:43 PM
Sounds to me like the normal tial blow off valve sound lol.
Car: 2007 BMW E90 335i
Default 06-28-2015, 04:58 PM
From your vid is sounds like the howl sound happens before the BOV even opens. Maybe the howl sound comes out of the air filters instead? This would make sense since the inlets would likely affect sound coming out of the filters.
ttuner's Avatar
ttuner ttuner is offline
Car: 2011 6MT Z4
Default 06-28-2015, 09:15 PM
thats how mine sounds. vvt inlets, tial bov, 11lb spring.
nyt nyt is offline
Car: 335ix
Default 06-28-2015, 09:49 PM
No sound if I pinch off the bov vac hose. It's def coming from the bov, and it makes the sound even when its full open. I might try some new springs and see if any change, really weird.
Default 06-28-2015, 10:32 PM
I'm running the 10 psi spring in mine and it makes the same sound with VTT inlets.
If its making the sound with the BOV stuck open wouldn't that suggest that it's not the BOV making the sound?
nyt nyt is offline
Car: 335ix
Default 06-28-2015, 10:49 PM
If I pinch the hose, the bov doesn't open, and no sound. It's coming from the BOV.
Nexic Nexic is offline
Car: '10 335i
Default 06-30-2015, 08:34 PM
I have forge DV venting to atmosphere and they make this exact same sound. This sound started after I installed my vtt inlets. I just did a turbo swap and ensured the inlets were attached securely to the turbos. I rebuilt the dvs twice now and it still makes this noise. I even swapped out the forge dvs with the stock ones and they also make the same noise. It's definitely something to do with the inlets, maybe due to the doubled flow/volume of air being moved?
bnk bnk is offline
Default 06-30-2015, 09:09 PM
Other upgraded inlets do not have this problem reported. Only VTT.
Car: '10 335i
Default 07-01-2015, 04:25 AM
Possibly a resonace issue specific to these inlets? Other than that I have no idea and it's bugging the crap out of me.
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 07-01-2015, 05:16 AM
I noticed that some bovs are cracked at idle, and some are closed at idle . I can't ever confirm what's it's supposed to be lol .
Car: '10 335i
Default 07-01-2015, 05:53 AM
My Forge DV's are full open at idle.
I think I may be on to something, after adding 1 then eventually 2 shims to the yellow springs in my Forge DV, it caused the sound to get louder. I took the 2 shims out and the sound lessened. I suspect it is due to the increase in CFM and volume of air moving through the intake tract. Since PSI is a unit of area and not volume, it stands to reason that when you increase the ability for turbos to move more air, the volume of air escaping from the BOV or DVs is doing so at a higher CFM. This may possibly cause the noise, as the piston opens the sounds from air passing by the surface opening make a "noise." Its like blowing across the opening of an open glass bottle, to little or too much and it does not make a noise. However, if you blow air at the right speed and the right volume across the top of a bottle, it will then make a howling noise.
ross22 ross22 is offline
Car: 2007 BMW 335i
Default 07-01-2015, 06:41 AM
I'm running the Tial and VTT inlets, got louder and higher pitch after the inlets went in. I am enjoying the sound of the howl for now.
J. Dub J. Dub is offline
Default 12-10-2015, 11:01 AM
Any update?
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 12-10-2015, 11:54 AM
https://youtu.be/6eygbk3NHVg
I have just installed RB inlets and the Bov is much more noticeable!
Default 12-10-2015, 12:02 PM
Why RB's over the shorter route of the "others"?
trebila's Avatar
trebila trebila is offline
Default 12-10-2015, 12:35 PM
With RB inlets and turbosmart diverter valves recirculating, I can definitly hear the DV noise.
It wasn't the case with stock inlets.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 12-10-2015, 12:55 PM
RHD ! Steering column in the way of tft etc
baja2700 baja2700 is offline
Default 12-10-2015, 01:57 PM
i havent had this issue with my 135 but on a previously turboed car i had the same noise but i was runing a HKS its been a while but i think i re adjusted my silicone inlet and clamps and tightened everything down and the noise went away. no idea if this will help but just my 2 cents
