Car: e46 323i/ 04.5 Turbo 350Z
New Differential Lock Down Brace -
09-30-2014, 01:02 PM
Hey everybody,
I haven’t posted here much since the forum was reset as you can tell by my post count. I spend most of my time on bimmerboost now. I just wanted to show you guys a diff lockdown brace I produced. I originally built this as a one off for BuraQ back in 2012. The goal was to have an affordable, durable, and easy installation. The results worked out as expected, minimized wheel hop and created overall tighter rear end.
The brace attaches to the bottom two differential cover bolts, and up to the subframe. No modification/drilling is needed. The subframes have holes there already.
Coming from the 350z and e36 community, it was not uncommon for people to run braces like this with great result. As more people are starting to make big power, I thought it was time to start producing these. The braces are hand made here in the USA out of steel. They are TIG welded, then finished with a black epoxy coating. Epoxy paints are more durable than powder coat. The Braces will also include 304SS hardware. I test fit every single brace made before coating to ensure fitment. That is a testament to how fast and easy installation is.
-Justin
http://boostaddictions.com/products/...e-for-e9x-335i
Notes:
1) 135i Fitment has been confirmed. Also see note 2.
2) Braces for Small differentials are now being produced.
3) For anybody interested in ordering, please confirm that the subframe hole locations are in the same position as marked in red in the picture below.
4) For International Orders please PM me so I can setup a Paypal Invoice and give you a shipping estimate.
Install Video:
http://youtu.be/P1Kwq3p7OzI
ex deus machina
Car: E92 N54 335i
09-30-2014, 01:30 PM
cool
much better then paying $726
Since the driveshaft spins clockwise and wants to pull the right side down and left side up, shouldn’t the support brace go across instead of in an angle?
Like this: Blue arrow stress point, Red arrow jerking motion, Black where cross brace should be
Daily: G30 M550i JB4
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPPK front & 50i rear brakes, M50d grill and trim
Gone: E92 N54 468wtq
09-30-2014, 01:40 PM
I Appreciate your input. Truthfully the support piece is not even necessary, it's just there for added structural integrity. When we first made this we weren't sure what type of force the brace would see. We just decided to keep it. From a fabrication standpoint, triangles tend to disperse force better, which is why we didn't put the piece like in your diagram. Maybe in the future we'll make one like you mentioned to see if there is any added benefit, as I understand what you mean with rotation.
Car: AW 335i
09-30-2014, 01:58 PM
Curious to know if this would work on the M3 LSD swapped into my car as well?
 2008 335i stock
09-30-2014, 02:10 PM
I'm not sure, I haven't been under an M3 in awhile to remember what the diff looks like. I've only been able to confirm fitment on e90/2 335i's with 6at/6mt/DCT
Car: E92
09-30-2014, 02:42 PM
Nice! Much better than $730.
Good work! What is the turnaround time?
TS N54
09-30-2014, 03:16 PM
I have 5 ready to ship now, and will have 4 more ready after the weekend.
ex deus machina
Car: E92 N54 335i
09-30-2014, 03:28 PM
weight of the unit?
warranty?
can we see preview of installation instructions?
Car: 2008 135i
09-30-2014, 07:04 PM
You should make one for the front end that also protects the oil pan like the e36 motorsports x brace.
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines
09-30-2014, 07:53 PM
Originally Posted by CHECKERED
weight of the unit?
warranty?
I've never weighed them but I would say under 3lbs
I'll provide a life time warranty for welds. I can't really provide a warranty for the coating since they can potentially be hit by debris while driving.
The plan this weekend is to put together a short youtube video showing installation using rhino ramps. Trust me it's literally a 5 minute thing once the car is up on ramps.
That's not a bad idea. I'll check how much clearance there is between the pan and splash guard next time I'm under the car.
Car: 2007 335i
09-30-2014, 08:14 PM
What are the trade-offs when you lock down the diff? Any known disadvantages to doing this?
2007 Monaco Blue E90 335i sport (auto) w/ JB4 G5 ISO, BMS DCI, BMS OCC, BMS DP's, BMS/Wedge e85 flash, Walbro inline fuel pump, ER CP, RB PCV , VRSF 7" FMIC, MFactory LSD
11.88 1/4 mile @118 on E60 with no meth
Car: 09 E92 335i
09-30-2014, 08:19 PM
Looks like an effective solution. But it seems like you do have to drill two holes into the rear sub frame.
09-30-2014, 08:32 PM
What I've noticed is, if you don't have good tires, you'll be spinning them a lot more.
No drilling is required. We used preexisting holes on the subframe.
Car: 09 E92 335i
09-30-2014, 09:06 PM
Great! Never notice there were holes on the subframe already. Will have double check if mines has it too. But that would make things a lot easier to install. Guess I just have to coat the bolts and any of the contact surface w/ anti-seize for rust protection during the winter.
Just curious if you guys ever run the kit on a road course too.
Car: BMW 135, Yamaha fz8
09-30-2014, 11:17 PM
Can this work on a 135 if not any plans to make one
Car: 2012 bmw 135i
10-01-2014, 12:16 AM
X2 im down for one if you do
2018 Individual Tanzanite Blue Competition M4
10-01-2014, 03:38 AM
x3. I'll also take one, if you can ship to South Africa.
 537.75HP 540.63TQ
Car: 335 - E92 - 6MT
10-01-2014, 04:14 AM
Very nice idea.
Rob Beck Turbos, PROcede Rev. 3, Procede Fueling Flash (via OpenFlash Tablet), PPS Methanol System (DO12/Aquamist Flow Sensor), DCI, Quaife LSD, BMW Performance Suspension, Autobahn Exotics Exhaust, Helix FMIC, AR Design ***, BSH Catch Can, Forge Diverter Valves, P3cars Vent Boost Gauge, Alufelgen CSL Reps, Lux 5.1 H8 Angel Eyes, HPB HID Fogs, LTBMW M3 Side Skirts, BMW M3 Rear Spoiler, BMW Front Aero Lip, BMW Pedal Kit, BMW M Shift Knob, Autotecknic Matte Black Grilles.
Car: 07 335i 6 speed
10-01-2014, 06:03 AM
The bolts are All stainless hardware. So rusting would me minimal to non-existant. Look forward to my diff brace! Gonna install this weekend.
10-01-2014, 06:33 AM
I haven't tested this on a road course yet. I would like to at some point. I would imagine the results would be similar to having a solid differential bushing.
Yes the hardware is Stainless as BME30 stated. They are marine grade nuts and bolts, so I would imagine they would hold up to the salt they use up north pretty well.
I haven't confirmed 135i fitment yet, but I'm 99% sure its the same thing. If one of you would like to be a tester let me know.
As for international shipping that's no problem. My website is not configured for International customers so we'll just use paypal Invoices for transactions.
Not New Member
Car: 2010 335i
10-01-2014, 07:44 AM
Why not bend the part out of one sheet metal piece (10 GA 1018 CRS) and weld a support rib or two onto it. Might be cheaper to manufacture/stronger/easier.
If you can give me mounting point dimensions, ill gladly draw something up as a concept in Solidworks
Car: 2010 335i 2006 325i 2001 325i
10-01-2014, 08:15 AM
any concerns about shearing those two diff bolts?
10-01-2014, 09:21 AM
I wonder how that would be from an aesthetic standpoint. I like that a normal person would never notice the piece as it is now.
I'm not gonna say it impossible as they are aluminum, but after 2 years of testing we didn't have any issue with them. I believe the other option also uses the diff bolts, and I haven't heard any reports of issues from their users.
Car: 09 E92 335i
10-01-2014, 10:11 AM
i don't know if this is different on other cars. But the holes on the rear subframe are much further apart the the bracket on this brace. Also, is this built for the smaller differential pumpkins or the older bigger one
Car: 09 E92 335i
10-01-2014, 10:32 AM
See this image.
Thread Tools |
Display Modes |
