Car: 135
Best n54 60-130 times -
01-20-2014, 04:18 PM
Where's the best place to look for n54 specific 60-130 times? I'm interested in the spread between a stock car, the fastest big turbos cars and everything in between.
I just got a Vbox so looking to compare. My best so far is 9.8 sec, but I was expecting a little better with FBO, E85 and meth.
I've seen lists on different forums, but haven't found any good posts that are very n54 specific and "60-130" isn't working very well as a search term in forums.
If anyone just wants to chime in with their best numbers and mods/conditions that's cool too.
Cheers
2009 135i 6MT Jet Black, FBO+
Pessimistic Poster
Car: 135i N54
01-20-2014, 05:50 PM
From what I've seen most stock turbos are in the 9's at best, maybe crack a high 8. There are so many factors though.
The Vishnu single did 6.4x though if you want to talk highly modded.
Car: '09 335i coupe
01-20-2014, 05:54 PM
Did you use a Vbox?
2014 2500 Cummins- Pretty much everything.
09' Single Turbo 335i SOLD
Car: 135
01-20-2014, 06:11 PM
Originally Posted by mjmarovi
Did you use a Vbox?
Yep.
Car: 135
01-20-2014, 06:16 PM
Hmm, thanks, that's the kind of info I was looking for.
Lots of factors for sure. 6.4 vs 9.8 is a huge difference...
Car: m3
01-20-2014, 08:14 PM
Just wait till you see a N54 project I'm putting together. The bar will be raised
abrhouston.com
832-797-9114
01-20-2014, 09:35 PM
I think themyst did a mid or low 8 second on stock turbos or rbs. shivs single did high 6's. terry also did low 8s didnt he? id say high 8s low 9s is average for stock turbo full bolt on, e85 mix, meth car.
Current: 2008 e92 335i coupe.
Car: 2008 BMW 335xi
01-20-2014, 10:05 PM
drag times has compilation of 60-130, last time i looked was couple 135/335 on 1st two pages // terry did 8.570 on stock turbos w the 135
JB4/G5 ISO ,AR DP,BMS DCI,NGK 5992 BMS Meth kit dual nozzle CM 7 & 5,VRSF 7 IC, Stett chargpipe, E60 mix, 255 Walbro, Bms Race flash. RB turbos , VTT inlets ,BMS OCC, 3.5 N20 sensor, Conti DWS
Car: 2008 135i
01-21-2014, 01:03 AM
I had low 9's before my inline pump went in on the BMS race flash, 40% E85, no meth. I'm running 60% now with a Wedge flash and there's a very noticeable difference.
2008 135i 4L80E Swap - 807 WHP VM 6466 Single Turbo Kit | JB4 | BMS Flash via MHD | Fuel-It Stage 3 | BMS Port Injection | E85
01-21-2014, 11:28 AM
I think Oldbooster has the record for 60-130.
Car: 09 135i
01-21-2014, 01:29 PM
Are there any fast z4 35i out there? Can you FBO them with 335/135 parts? I rarely see them talked about.
Car: 08 135i FBO
01-21-2014, 02:31 PM
Same JB4, different DP, different charge pipe, different fmic.
Car: 08 E92 335i
01-21-2014, 04:19 PM
My best 60-130 time with RB turbos is 7.55 sec, running on a E50 Map.
Thread Tools |
Display Modes |
