135i_AKA_TheVesuvius 135i_AKA_TheVesuvius is offline
Car: 135I
Default What mods do you run? How long running? What would you have done differently? - 01-11-2014, 07:44 PM
Hey, new 1er owner here looking to get some knowledge from the experienced owners. Im looking to start modding my 135 but want to get some time with her stock before modding. Just wanted to see what people are running and for how long. Also knowing what you know now would you have done anything differently?
paco11484 paco11484 is offline
Default 01-13-2014, 08:39 AM
Welcome! I've had my 135i for about 8 months now. I LOVE it.
When I got it it had wheels and non runflats, and a bunch of carbon fiber bits. Everyone says upgrading from runflats makes a big difference.
Within 48 hours I went on a shopping spree. DCI, JB4, ******* *********, upgraded FMIC, and WW Water Meth. From the time of buying the car I went from stock to FBO in about a week.
A few months later I did the Alpina flash and noticed a huge difference that made.
If I was to do it again, I'd of bought BMS ********* instead of saving a few bucks with the Racelands. Secondly I'd of bought a trunk mounted water/meth setup. I have had nothing but problems keeping my kit primed.
08 AW 135i - JB4 G5 ISO, WW Water Meth, BMS DCI, Raceland *********, VRSF Intercooler, Alpina Trans Flash
02 Subaru WRX - TD05-18g, modded stock injectors, 3" turbo back exhaust....and the list goes on.
Trickcruiser's Avatar
Default 01-15-2014, 07:57 AM
First, welcome and congrats on the new car!
I have had my 135i AT for just over 2 years now. Bought the car with 30k and it is now at 55k. The only issues I have had are the normal things like plugs, coil packs, and vanos solenoide.
For performance, I was Full Bolt On with meth from the start (came from a FBO 335i). For the last 10k, the car has been running RB turbos, flash tune, and Walbro 455 in tank pump for E60. I could not ask more out of the car (with the exception of getting that 10 second #@$%#$$#@% pass LOL).
Now if I were to start all over I would do the following mods in this order:
1 - JB4 ISO
2 - BMS Intakes
3 - BMS E85 flash
4 - Walbro inline E85 pump
5 - Alpina Trans Flash
This alone should be right around 380-400whp vs the stock 280ish whp!
After this you want to look at the things that will help you sustain that power. They will all add some power to the mix as well but not in huge chunks like the items above.
5 - ******* ********* - I have used both the AR and BB. There have been great reviews on the BMS cost effective offering. If I started from scratch I would go with BMS because Terry stands behind everything so amazing well.
6 - Front Mount Intercooler
7 - BMS Catch Can
8 - Charge Pipe with BOV & Meth bungs
9 - Meth
Next level would be either upgraded twins (I highly recommend RB's).
Thats about all I can think off right now...
BimmerNFS's Avatar
BimmerNFS BimmerNFS is offline
Car: 2009 BMW 335i E90
Default 01-15-2014, 02:02 PM
1 - JB4 ISO
2 - BMS Intakes
3 - BMS E85 flash
7 - BMS Catch Can
9 - Meth
I agree with all of this. Personally, I would move the Chargepipe and the Catch Can to probably #2 and #3. I only got 2-3 months on the stock chargepipe before it blew. The catch can i moved that up just to help prevent further $$$ down the road.
2009 BMW e90 335i 6AT, Sport Package, Cold Weather Package, Premium Package, Logic 7, Space Gray Metallic, Dakota Gray Leather
BMS DCI, BMS JB4 G5 ISO, BMS OCC, BMS CP
DaleM's Avatar
DaleM DaleM is offline
Band
Default 01-15-2014, 04:37 PM
Got my car in Germany in Jul 2008, sometimes I wish I had gotten the sun roof delete.
My car is getting ready to hit 40K miles. I tried to sell her because my back going south after 2 surgeries on the c-spine at multi-levels. No one wanted her so I am moving forward with taking her back to Sebraing for some runs and SCCA events when I have the time.
1. JB3 then JB4 now JB4 G5. I had pin outs and then the PnP.
2. Blow off valves
3. BMS DCI (dual cone intake)
4. camber plates
5. Helix Intercooler
6. M3 sway bar
7. Cooling Mist meth injection (C12 nozzle)
8. Chatless Down *****
9. Meisterschaft full chatless exhaust
10. BMS clutch valve
11. Bavarian technic scanner cable kit
12. NGK plugs
13. Strut tower brace
14. BMS cowl filters
15 Kensinger (sp) shifter
16. Stainless steel brake lines
17. A wheel tire combo to widen the stance, a group sale years ago, still love the feel.
18. ClutchMaster FX400 550hp rated clutch
probably a few other things.
She dyno'd 420rwhp and 460lbsft torque in Jul this year. That was on map 7 with some 110 leaded added and the JB4 G4. Looking to go back with the JB4 G5 and try a product called Race-Gas once i test its additive properties. It has MMTs and Aromatics added (likely toluene or xylene). the beauty is not having to hunt around for 100-105 unleaded. you make your own.
Vae Victis!
If you are not going Juice Box then you are going slow.
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 01-22-2014, 03:02 PM
My car is a 2011 BMW N55 135i. It has 389whp.
Mods have been on there since 2011. Wouldn't change a thing but kind of want the 1M mirrors and to upgrade the headlights to the new ones with the LED eyebrow.
The car is so awesome. Such a good daily driver too.
1. N55 JB4
2. BMS N55 Performance Intake
3. BMS Oil Catch Can
4. BMS Low Temperature Thermostat
5. BMS N55 ********
6. BMS wheel spacers 10mm front & 15mm rear
7. BMW Performance Seats
8. BMW Performance Steering Wheel (non-electric)
9. OEM BMW 2012 135i Taillights
10. BMS 2.3 Gallon Trunk Mounted Methanol Kit
11. Hardwired Valentine 1
12. Black OEM Grills
13. BMS 6000K LED Angel Eyes
14. BMS Cowl Filters
15. BMS LED License Plate Lights
16. BMS N55 Chargepipe
17. Big Ebay Intercooler
Msroka Msroka is offline
Car: 08 135i BMW
Default 05-09-2014, 09:02 AM
Did anyone ever run 100% meth with 50% e85 on stock n54 with stock turbos?
Randy7fx's Avatar
Randy7fx Randy7fx is offline
Car: X1
Default 05-09-2014, 10:45 AM
1 - JB4 ISO
2 - BMS Intakes
3 - BMS E85 flash
Curious, does the alpina trans flash actually add power? Thanks!
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 05-09-2014, 02:38 PM
It doesn't add power, but here is what you do get...
1) Faster/cleaner upshifts and downshifts
2) Better management of higher torque requests.
It really is worth it.
galifardo1971 galifardo1971 is offline
Car: 2012 135i n55
Default 09-23-2017, 08:21 PM
where to buy the alpina trans flash? thanks
2012 135i n55
Active Autowerke FMIC and DP, Injen Intake
seroga1986's Avatar
seroga1986 seroga1986 is offline
Default 09-24-2017, 04:19 PM
Mods in description. 56k miles on car, 38k miles tuned with jb4. Last 15k with inlets and 23psi on the street. Hard street miles.. About 4-5 track days a year all on map7 (19psi). Many 1/4 mile runs. Many drag races with buddies. So far so good no major issues just regular maintenance.
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
mattgu40 mattgu40 is offline
Default 09-25-2017, 12:20 AM
First to last mods,
e92 335xi pre lci sport pack
jet black with dakota brown interior
Jb4
vrsf *********
bms occ
dci
charge pipe +bov
backend flash
vrsf fmic
bms wmi dual cm5 added inline checkvalve nozzle holder 90/10 mix, (dumping the bov through a 1 1/4 hose routed away from any ignition source)
vac line upgrade
bmw PE
vibrant resonator instead of mid *****
Ecs drill and sloted rotor kit
arc 8 profile 2 front 3 rear with Pss
kw v1 coilovers
bucketless stage 2 lpfp
antilag + 2 step
3.5bar tmap
running e50
21psi peak tapering to 16.7 pulls like a mother****er
and the UPS guy got a set of vtt GC and bigger meth nozzles comming my way.
then i will get tribla make all of this work strong and smooth
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-25-2017, 01:30 PM
Just go for the XHP stage 3. Easy install and most people claim it's better than alpina.
