supermac's Avatar
supermac supermac is offline
Default alpina trans flash in clt. - 04-10-2013, 06:49 PM
If anyone needs a flash in the cornelius/nc area, hit me up. I can help.
Turbo PWC performance www.macsboost.com
08xi, jb4 Iso, meth with 2.5gal trunk mount reservoir, CPE *********, alpina trans flash, MACSBOOST IC. Occ catch can, External C&R oil cooler, macsboost rear suspension rod end adapters. H&R sport springs, koni fsd. 12.25@ 113.21mph @ ZMAX dragway.
iv55 iv55 is offline
Car: 2007 335i coupe
Default 05-27-2013, 09:39 AM
pm sent
2007 E92 N54, JB4 G5 ISO W/ BMS Flash, RB Turbos, Meth W/ FSB & CM10, BMS DCI, BMS OCC, CPE FMIC, AR Design CLDP's, DP Fix, Quaife LSD
Syclone Syclone is offline
Car: 2008 E88 135i Convertiblev
Default 08-01-2013, 06:11 PM
How much do you charge?
massekizzem massekizzem is offline
Default 10-17-2014, 08:01 PM
Still trying to find someone in clt to do this.
Default 10-18-2014, 04:42 AM
I can do it for you. I am in lake Wylie area. Only on weekends though.
Jeff
Lake Wylie, SC
2008 BMW 135i E88 Convertible
Blue/Black
Koni STR.T suspension, M3 Front suspension arms
JB4 Map 7, E85 Backend flash, Fuelit stage 2 fuel pump, Mechtech Intercooler, Raceland ***, NGK Sparkplugs, BMS DCi, Alpina Trans flash, BMS silicon inlets, BMS charge pipe.
