Car: 335is
BMS Flash + G5 ISO Logs + Dyno added! -
11-20-2012, 10:20 AM
I recently got the flash and let it autotune and here are a couple of logs of 13B firmware. They look good! 5 gallons of E85 and 10 gallons of 93. 43' temperature.
2011 E92 335is 6MT - Everything except Logic7 but MusicarNW + Technic FTW!
Mods - JB4 G5, Cobb BMS Flash, 5" ETS IC, Injen Intake, AR ***, ER CP, Forge DV, M3 suspension kit (front), H&R Sport Springs, Performance Shift Knob (adds 50whp!)
Car: 2007 E90 335i A/T
11-20-2012, 03:24 PM
Looks good from what i can tell. I guess the first log was leanrning thats why the jumpy boost.
I think you can go from the 33% E85 to 40-50% E85 and even try map7 if the LPFP and the HPFP can keep up.
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
Car: 335is
Dyno Graphs and JB4 Logs -
11-26-2012, 09:32 AM
I did a dyno baseline last Wednesday and here are the results.
Mods are in my signature and running 6 gallons of E85 + 10 gallons of 93
Reason: Updated from SAE to STD
11-26-2012, 09:47 AM
Nice! Could use a little more E85 for timing, but looks good! Out of curiosity, do you get a vibration/grainy noise if you go WOT in 4-6 below 3500rpm? I get a weird noise at full boost and low rpm and believe it is the clutch, transmission, or DVs.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
11-26-2012, 09:50 AM
Looks pretty good for STD numbers. +1 on a bit more E85 for the map 7. I think I'll shave maybe 1/2 - 1psi off the higher RPM map 7 targets as it looks like stock turbo cars are having a hard time hitting them.
Car: 335is
11-26-2012, 10:03 AM
Not that I recall but I'll try to listen in on this now.
11-26-2012, 10:16 AM
I was messing with some experimental firmware and had a bunch of diverter noise and along with it came that grainy/vibration sound. I ask because you have upgraded DVs. I didn't think this sound could be related to DVs, but maybe they are fluttering. I don't know.
2008 335i Coupe 6MT
Car: 335i 318ti
11-26-2012, 10:53 AM
Still autotuning I'm guessing. Boost is rising w/ every log.
One tire fire
Car: E92 335, 6MT
11-26-2012, 01:13 PM
All 6MT cars do this. It comes from producing excessive torque low in the RPM band. I think it's something torquing over and vibrating on a subframe or something. Possibly the diff/diff mounts. My previous 07 did it once it started making a lot of torque. My 09 does it as well as any other tuned 6MT 335 I've ridden in. A lot of people don't load their car up down that low and some just don't even notice it until you point it out.
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
'09 997.1 6MT: FBO, 65mm VTGs. 730 whp
'18 Nardo Gray RS3 APR stage 2, 10.72 @ 130
11-26-2012, 01:15 PM
Yep. Maybe input shaft, clutch, etc. It is definitely noticeable and sometimes louder than other times.
2008 335i Coupe 6MT
Car: e92 335i 6spd
11-26-2012, 01:31 PM
Damn that's the same WTQ that I made lol
Car: 335is
11-26-2012, 03:32 PM
Yeah it was on SAE. I changed it to STD but Uncorrected is about 507. I am not sure which one you used. Either way they are both a lot and I love it!
Car: e92 N54 335i
11-26-2012, 03:38 PM
i recently noticed it too under heavier throttle at the beginning of boost onset at lower-to-mid rpm. It's a prominent resonance
Do you have DCI? If you do and replace it with the stock intake, the sound virtually goes away.
11-26-2012, 04:59 PM
I definitely do have a DCI. If that is the case, that is more reason to suspect that it is a diverter valve issue since DCIs will make it much easier to hear the DVs. Maybe they are fluttering...
2008 335i Coupe 6MT
Car: BMW 135i M-Sport
01-29-2014, 12:47 AM
Rudypoochris & bmw loe; did you figure out what your fluttering/noise issue was?
Thread Tools |
Display Modes |
