N55 Stage 1 HPFP Upgrade
SKU: DE-55-1001 Categories: BMW, N55
This is a complete plug-and-play kit to support up to 550whp (this number can vary quite a bit depending on tuning strategy and the blend of ethanol). Theres no cutting, no bending, no crimping, etc. This kit drops right in with full control from the DME, just like the OEM pump. All of the safety and sophistication of the stock DME remain in place.
N55 HPFP Flow Capacities
The table below serves as a reference for maximum fuel flow in cubic centimeters per camshaft revolution for various N55 fuel pump options. These calculations are based on the N55 cam lobe. Each engine will have varying fuel flow capacities depending on the lift and number of lobes on the camshaft.
Pump Model Fuel Flow (cc/rev)
HDP5 (Stock N55) 0.837
HDP5 Evo (Stock B58) 0.897
HDP6 (Stock B58TU) 1.107
Dorch Engineering Stage 1 1.221
Dorch Engineering Stage 2 1.465
Software changes are required to run this pump. If using MHD or Bootmod3, simply check the box for our pump upgrade when flashing (coming soon). Otherwise, please send your .BIN file to
tuning@dorchengineering.com for the appropriate software changes. This change is free of charge for all of our customers.
Kit Contents:
HPFP w/ Hardware
High Pressure Line
Low Pressure Line
Low Pressure Line Bracket
Plug-n-Play Adapter Harness
Kit Fitment:
F87 M2
F20/21 135i
F22 235i, 235xi
F30 335i, 335xi
F32 435i, 435xi
F10 535i, 535xi
E92 335i (ONLY 2012+ models originally equipped with Bosch HPFP)
E82 135i (ONLY 2012+ models originally equipped with Bosch HPFP)
