Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Default N54 Index 12 Help - 05-15-2020, 10:24 PM
Hello everybody, today I got in the mail my brand new index 12’s. Well ( Remanufactured) but new to me. So I’ve been doing some research and haven’t noticed my problems. When coding I’ve noticed that nobody else has the same exact numbers from one injector to another, in my order today I have 2 of the same exact numbers. And I was hoping someone with some knowledge about this could help me out.
1. 576 204
2. 579 221
3. 579 221
4. 576 192
5. 563 261
6. 565 225
This is not in any specific order it’s just the order I took them out the box. I’m wondering if 2 & 3 are going to be a problem when it comes down to coding the injectors. Now also is there a specific way from the numbers it should be installed? Thanks for the help Guys & Girls!
Default 05-16-2020, 06:11 AM
I didn’t know our injectors could be remanned?
Where’d you get them?
Car: N54 335i
Default 05-16-2020, 08:12 AM
Hey Dave, maybe I’m wrong then, to my understanding FCP EURO sells remanufactured index 12’s.
nhatnguyen14's Avatar
nhatnguyen14 nhatnguyen14 is offline
Car: N54 E89
Default 05-16-2020, 08:57 AM
don't think it will be a problem if they are the same. i cheaped out and ordered some on ebay and they end up the exact same number. programmed them with the same and it worked fine. had to replace with the new ones from FCP now.
codesx's Avatar
codesx codesx is offline
Default 05-21-2020, 08:48 AM
We've seen a similar post, where the re-manufactured was a total scam. (ebay)
However, I've also read that FCPEuro (alone) has the required vendor relationships to be able to offer this legitimately.
As stated, you should have zero issue if two (or any qty) happen to have the same values. Simply code appropriately.
Simply curious;
I've heard that FCP Euro has these in stock - sometimes, but not often.
Do you mind sharing what you paid (even approx) for them, vs. a new set?
Also, did they offer the same life-time warranty as all their other products?
I bought new from them a bit ago and am very happy.
I find it surprising that there are already 'remanufactured' Index 12, as they are still the latest iteration. Makes one wonder what failed and if it may reoccur.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 05-21-2020, 09:28 AM
Index 12 have been out many years now.
09 335 - 6266
07 335i - 6870, E85 - SOLD
ajsalida ajsalida is offline
Car: e92 335xi
Default 05-22-2020, 12:11 PM
Good article here on what is done:
You Can Now Buy Remanufactured BMW N54 (Index 12) Fuel Injectors Through FCP Euro
Out of stock though.
Car: N54 335i
Default 05-24-2020, 05:16 AM
Hey guys, I put my injectors in last week and coded with protool and everything is working great! Thanks for all the help guys/girls!
