Originally Posted by unknownz24
Right, my bad. I've been running map 1 and haven't been logging for a while so I've forgotten a few names etc
Last BEF was Pump. I haven't changed any settings since then, everything was running great, was even getting good results with Map 6 and 7 per your guidance. Then recently I've been getting Safety 2 in map 1.
As I said, thought it was the O2 sensor based on the code, but after putting in new ones and resetting the adaptations, I'm still getting Safety 2.
I'll double check my settings and BEF, but as far as I know I haven't changed anything
Did you replace your primaries or secondary?
I’d do an o2 reset see if that brings the AFR back to normal at least temporarily- if they start to get wonky after the reset (or nothing changes)- you’ll know the primary bank 1/2 would need replacing
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways.
Please click here for more information on legal requirements related to use of BMS parts.
