Nin478 Nin478 is offline
Car: 2008 335i
Default Installed new injectors, getting a bunch of codes now - 04-29-2020, 06:53 AM
So I've got a 2008 335i and replaced bank 2 Index 7 injectors with Index 12 along with OFHG and serpentine belt. Used Pro Tools to code them and double and triple checked the numbers. Now when I go to start the car I get these codes:
29D0: Misfire cylinder 4
29D1: Misfire cylinder 5
29D2: Misfire cylinder 6
2E1C: Firing, Cylinder 5
Shadow Codes:
2FCA: Fuel high pressure
2FDA: Crankshaft sensor, signal missing
When I started the car it did take a couple seconds for it to start and then had a rough idle. The car has never had an issue starting up before. All parts were purchased through FCPEuro. I'm on MHD Stage 2+ with MSD80 if that's any help. Any thoughts on why I'm misfiring and suddenly it's taking longer to crank?
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 04-29-2020, 07:21 AM
The first start after replacing injectors is always extremely rough and will often throw several codes due to air in the system, etc. Some adaptation time may be required or an adaptation reset.
If the issues persist there could be an installation problem. Either way I would first check your wiring due to the CPS code, maybe a connector was bumped or left loose during your work as you did several repairs.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 04-29-2020, 09:51 AM
How do you know your injectors were bad?
09 335 - 6266
07 335i - 6870, E85 - SOLD
