(#701)
Default 03-07-2020, 06:02 AM
Originally Posted by Sekans
George if you're out there,
How accurate is the e85 reading on our cars? Does it mean anything?
I recently started looking at logs and noticed that sometimes mine reads 0, sometimes 12ish, and sometimes as high as 48. When I spotted the 48 it worried me because I've never tried to pump any e85, and all the pumps here are marked e10.
Also are there any recommendations about running e85 mixes? Or is the stock engine best staying away?
Ignore it for now. We trying to get a virtual reading working but not having much success as this stage.
Vadellas Vadellas is offline
Car: Skoda 1.8 ea888
Default 03-08-2020, 01:47 PM
Hello George. Do you have any plans to do something for DSG?
Default 03-08-2020, 02:56 PM
No plans for a DSG flash.
ZuMBLe ZuMBLe is offline
Car: VW Alltrack
Default 03-08-2020, 05:04 PM
How do we get the JB4 (android) app to see the latest firmware? It's only showing the previous firmware as an option to download.
Default 03-11-2020, 11:45 AM
App developer needs to do a fix for that.
luke_s3 luke_s3 is offline
Car: '17 S3 Sportback
Default 03-12-2020, 06:02 AM
Hi, installed a JB4 in my S3 FL last week. I updated to latest firmware and put it on Map 4 as it is mapped with the 7 speed in mind, what exactly does the taper at higher rpms do for this map?
I'm wanting to know whether Map 2 or 3 produces more power/or is more aggressive than that of Map 4.
Also, has anyone here tried launch control but their boost gauge no longer goes to around 100% in the VC? Instead it only reaches about 80% max boost in the gauge?
Default 03-12-2020, 06:06 AM
On the 7 speed Haldex cars we are forced to taper boost as the car has issues only when launch control is used.
When using it you are seeing less boost as the JB4 is fooling the ECU to build more than stock of the line.
Ketchup Ketchup is offline
Car: 2018 VW GTI S w/DSG
Default 03-15-2020, 01:51 PM
Hi!
I just installed my JB4 on my 2018 VW GTI S w/DSG. I drove it around for about 10 miles and didn't get to really get on it due to the weather.
What map will it run for a new install and what should I notice?
Does it take a while to "learn"?
Were does the Bluetooth module plug in and do I need to route that through the firewall, too? (going to get it in about a week.)
Thank you!
In California on 91 gas.
Default 03-15-2020, 02:01 PM
Originally Posted by Ketchup
Hi!
Thank you!
It ships in map 1 which is good for 91.
Below 170F water temperature the JB4 is inactive so on a short ride potentially the car was still cold and you wouldnt notice any difference to stock.
Here is a install guide for the BT, no need to route anything with that: https://s3.us-east-2.amazonaws.com/d...ide+1-5-19.pdf
Default 03-15-2020, 02:07 PM
OK. Thank you!
I'll go drive around and get it warmed up and see what I see.
I just watched the BT install video on Youtoube. Simple install :-)
Default 03-16-2020, 05:04 AM
Got it really warmed up. Long straight road and needed to pass some....one word...WOW!
Thank you!
Default 03-16-2020, 03:16 PM
Thank you!
passatvr6 passatvr6 is offline
Car: VW
Default 03-16-2020, 04:13 PM
Hello George,
Does Map 4 put our more power than Map 2 up top above 5000rpm?
Let's be honest..power under the curve above 5K is all that matters
Default 03-16-2020, 05:04 PM
Originally Posted by passatvr6
Hello George,
Map2 would be a bit stronger.
Car: VW Alltrack
Default 03-17-2020, 10:24 AM
This looks to be fixed in the app now. This is why I love you guys. Great support.
Car: VW Alltrack
Default 03-17-2020, 09:26 PM
George,
I think I found a problem with the latest firmware. The JB4 app log says I pushed 33 psi of boost, then the JB4 kicked me in to map 8. This is all when I was in map zero. Sent you the log.
There is no way the sensor actually saw 33 psi or passed a 33 psi signal on to the ECU because my timing would have bottomed out and my FP_H would have took a nose dive. I'm sure the car would have felt like a damn rocketship before the motor blew up too.
drsnowmon drsnowmon is offline
Car: 2019 Golf GTI
Default 03-18-2020, 11:51 AM
I looked everywhere on this forum but could not find my answer
The question I have is, can I run map 3 and change the boost from:
map 3
from
1500 - 15
2000 - 16
2500 - 17
to
1500 - 16
2000 - 17
2500 - 18
I have mk7.5 GTI, always running on 93 octane
Thanks,
Default 03-18-2020, 03:35 PM
map 3
from
1500 - 15
2000 - 16
2500 - 17
to
1500 - 16
2000 - 17
2500 - 18
Thanks,
Map 3 is a preset map and wont allow for boost changes.
What you are seeing in that chart is the boost the JB4 uses when map 6 is selected.
Car: 2019 Golf GTI
Thumbs up 03-18-2020, 03:59 PM
Ringo_Stingo Ringo_Stingo is offline
Car: 2019 VW Alltrack
Default 03-22-2020, 12:12 PM
On my 2019 DSG Alltrack, additive maps seem to build more boost, at lower RPMs...which works well for the serpentine roads, in this area. Below is one Map6 config that I'm using with seemingly good results, with little or no ign correction, w/ 93 oct. This map seems a bit stronger than map 2 or 4, under 4500 RPM. Anyone try a similar map? A similar config, with a bit more boost, up to 3500 seems better still, but might too much.
1500 - 1.6
2000 - 2.1
2500 - 3.0
3000 - 4.0
3500 - 4.0
4000 - 5.0
4500 - 5.5
5000 - 5.5
5500 - 5.5
5500 - 5.0
6000 - 4.5
6500 - 4.0
7000 - 4.0
Car: 2019 Golf GTI
Thumbs up 03-23-2020, 02:48 AM
1500 - 1.6
2000 - 2.1
2500 - 3.0
3000 - 4.0
3500 - 4.0
4000 - 5.0
4500 - 5.5
5000 - 5.5
5500 - 5.5
5500 - 5.0
6000 - 4.5
6500 - 4.0
7000 - 4.0
Hello Ringo_Stingo,
Those numbers look very interesting and aggressive which I like. Do you have any mods other than the JB4? Also can you interpret it for me in total psi? My JB4 mobile app I'm using does not show additive psi so my numbers are like 15, 16, 18, 20....
Thanks,
Default 03-23-2020, 06:36 AM
Hello Ringo_Stingo,
Thanks,
The values you have are absolute targeting. The ones in the post above are additive so boost value over ECU request. You can punch them in and see what the total boost is in the display or you can run a log. Total boost will vary based on intake temperature as the ECU targets torque using intake temp as one of the parameters in the calculation algorithm.
Default 03-23-2020, 06:55 AM
George,
I recall that you said Map4 is additive. Can you please confirm that Map2 is also additive? Are the targets from my Map6 higher than Map2, under 4000 RPM?
Thank you
Default 03-23-2020, 07:03 AM
George,
Thank you
Map 1 to 4 are all additive.
Similar to yours. They starts with 2 and by 2500 are at 3.
Car: 2019 Golf GTI
Default 03-23-2020, 12:20 PM
Thanks for your explanation that makes sense
Also for someone who has MK7.5, 93 octane, no mods, is it safe to set peak boost higher than 23 by raising failsafe psi higher?
