(#26)
Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default 08-10-2016, 01:43 PM
anyone with a solution to this?
its obnoxiously loud
does changing the bov spring to a lower rated one and/or tapping the
manifold with a bigger bov vacuum hose really work , as suggested by some?
Torgus Torgus is offline
Car: 335xi
Default 08-10-2016, 02:06 PM
I would try putting the correctly sized vac hose to the BOV. The stock line is too small per Tial specs.
Got Boost?
Car: BMW 335I N54
Default 08-10-2016, 02:55 PM
yes this is next on my list
S.W.G. S.W.G. is offline
Default 08-10-2016, 05:08 PM
Mine sounds very similar. I upgraded to a 1/4" hose and outlet as well.
https://www.youtube.com/watch?v=RITzLCv4WB0
Beemin Beemin is offline
Car: 2007 e92 335i
Default 08-10-2016, 07:21 PM
I have the hotside aluminum inlets along with aluminum outlets and I get this sound with stock DVs venting to atmosphere.
Just like the OP's video, the high pitch sound happens a split second before the standard DV/blow off sound and mind sounds like it's coming from the passenger side. It's almost like the DV's can't release quick enough.
I'm going to try the 1/4 hose and barb to see if that helps.
Car: BMW 1M Coupe
Default 08-10-2016, 07:43 PM
to chime in, i'm running Pure turbos with VTT inlets and it sounds like that too! car have been running fine, 27PSI with no issues for around 10,000kms so i wouldn't be too bothered by it. logs look nice as well. I would say that the noise is probably just the character of the inlets.
Car: BMW 335I N54
Default 08-11-2016, 02:57 PM
https://www.youtube.com/watch?v=QYbf-SWsz14
I think its too loud.. the old pssss sound was better..
Grunt Grunt is offline
Car: 335is
Default 01-01-2020, 06:41 PM
Thread revival, sorry......
I've been researching this since I put my inlets on a few months ago. I just found this thread and this video is exactly the sound I have that I do not like at all. MMP inlets on VRSF c.p. and Tial bov on custom tune at 22psi and all the other usual bolt ons. Has anyone found a cure for this possibly? Different spring than standard in the bov? Different bov?
nyt nyt is offline
Car: 335ix
Default 01-01-2020, 08:11 PM
I think it's a resonance from the silicone intake tubing and nothing you can do aside from running hard lines will fix it.
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
