Originally Posted by iminhell1
Based on my engine, that compression is low. I'm running about 185 across the board.
But if the rings are dry, and now fuel washed, maybe that's why you seem low.
I kinda want to say to remove fuel and toss in some light oil to get the rings to grab again. Let it sit wet overnight to get a good soak. Then add fuel again and see if it'll pop off.
But it could be timing jumped. I don't know these things well enough to know how much compression drops per tooth, but roughly 40 psi sounds like it might be possible. You'd think it'd throw a vanos code though, even on just cranking.
thank you all for the input, I think i found the problem.
I was playing around with ista d earlier today and under vehicle management---->troubleshooting---> text search, i typed in N54 timing and there were instructions there on how to verify timing.
i followed the instructions and was able to confirm exhaust cam was off about 3 to 4 teeth
took a while but i was able to time the camshafts without a timing tool as the instruction already explained how everything was supposed to be lined up
Ran the compression test again with the valve cover still off and
cylinder 1 - 185
cylinder 2 - 185
cylinder 3 - 210
cylinder 4- 180
cylinder 5 - 195
cylinder 6 - 195
i think its safe to say my valves are still intact, but i am trying to figure out what caused the car to skip timing initially before i put everything back together.
