(#1701)
Pumaman Pumaman is offline
Car: 2017 bmw 440i
Default Upload error everytime. Help please!!! - 08-26-2019, 02:49 PM
I’m updating my 440i with what I thought was the correct B58 hex 13 file. However it won’t move past 10 files and tells me it’s an upload error. Now I can’t do anything for maps. Help please!!
biocops biocops is offline
Car: BMW 530i M sport
Default Firmware ver 11 - 08-26-2019, 04:09 PM
Hi, I’m new here and I can’t seem to get the firmware download for version 11. Pls assist to guide me to the correct page. Thanks in advance
mesor mesor is offline
Car: M140i
Default 09-09-2019, 05:09 AM
Hello from Germany,
My M140i MY2018 suddenly changes the map after a short drive, from map 2 to map 8,
map1 and 3 works fine.
How can that be?
Latest Firmware is installed, car is stock, fuel is 100 RON.
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 09-09-2019, 05:37 AM
I had the same issue - do it when the car is cold. if your bluetooth make sure nothing else is connected.. try to get as close as possible to the car.
I had to do it like 10 times!!! before it took!!
Then make sure your FUD is properly set or you will be running on backend flash settings - which dont work well on a non-flashed car.
BMW After BMW
Car: BMW M240i
Default 09-09-2019, 06:32 AM
Is it also possible you’re triggering safety mode? I think 8 was safety mode map, but I may have forgotten.
Bmw_ire_2012 Bmw_ire_2012 is offline
Car: M240i
Default 09-10-2019, 01:59 AM
What's the lastest firmware version for the b58, I see many I'm guessing it's 14?
xz329 xz329 is offline
Car: F30 330e
Default 09-10-2019, 08:19 AM
how do i upgrade my firmware for b48?
BMW After BMW
Car: BMW M240i
Default 09-10-2019, 09:56 AM
There are messages and videos explaining it on the main b58 thread.
Elfeix Elfeix is offline
Car: M240
Default Can bus control - 09-25-2019, 05:41 AM
How to control the can exaust in map 2 and 3 by bluetooth?
335i101 335i101 is offline
Car: 07' 335 Cpe
Default 10-04-2019, 07:31 PM
Installing in Supra tomorrow. Just confirming the map guide at the beginning of this thread is not accurate and I should use the map guide listed on the BEF thread? Even if I don’t have a BEF?
Default 10-04-2019, 10:10 PM
The BEF guide is for BEF settings, so use the normal guide if not running a BEF.
B58_M240 B58_M240 is offline
Car: M240i
Default Meth Setings Guide - 11-07-2019, 07:41 AM
Terry,
Is there an updated Meth guide for v14 posted up someplace or can we get an updated one?
Thanks!!
fjsato fjsato is offline
Car: Mini Cooper S 2.0 aut
Default 11-08-2019, 04:36 AM
I can use this v14 firmware in a F56 JCW LCI? Tks!
Lira Lira is offline
Car: BMW M3 e36
Default 320i 2020 G20 B48 184cv - 11-10-2019, 08:43 PM
Is there any firmware update for installation on a BMW 320i 2020 G20 chassis with 2.0T B48 184cv engine?
would the v14 version work without problems?
Antec800 Antec800 is offline
Car: 340ix
Default 11-10-2019, 09:08 PM
Should work well with the b48 or whatever is in the 320i, but the jb4 does not work well for the m340i which has a completely different version of the b58 engine then older 340s
dkstas dkstas is offline
Car: 2020 Supra
Default 11-24-2019, 03:59 PM
Any one do a map 6 for the A90 Supra?
luchocamp's Avatar
Default 11-24-2019, 04:49 PM
stock flash is 14.7 to 14.9 AFR
use a back end flash to optimize JB4 on map 6
18 BMW XXXX Car in Process
tegxsi tegxsi is offline
Car: RS3
Default 12-09-2019, 08:28 AM
I'm looking into M340i. Is mixing E85 still an issue on B58 that comes on the G20s?
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Default 12-09-2019, 11:20 AM
Mild mixes without a flash is doable.
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default Jb4 on m340xi 2020 - 12-10-2019, 08:56 AM
I have old jb4 b58...I will install on new 2020 m340xi today
My question.. I just need to flash with last firmware? And go? Or anything to do?
And on this jb4 I have 3 connectord on this jb4...seem only 2 on new one?
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
Default 12-10-2019, 09:43 AM
Update firmware and go. EWG connection remains optional!
BobVader's Avatar
Car: 335xi 2008
Default 12-10-2019, 02:08 PM
BobVader's Avatar
Car: 335xi 2008
Default Problem update firmware? - 12-10-2019, 03:19 PM
I try to update but all four firmware here... checksum error at the end.
My jb4 b58 had 2 years... maybe another firmware need?
Thank
Weird... at the 5th time... all work
Default 12-11-2019, 03:31 PM
Thank
It takes a few tries if you have wifi on, or if the phone isn't too close to the JB4 system.
Glad you got it done!
JBoe JBoe is offline
Car: M240i
Default 12-14-2019, 10:28 PM
I'm getting too much wheel spin at launch. I'd like to adjust "max boost" to see if I can improve my launch. How does that work now? I was using peak boost target numbers (absolutes like 14 or 17), but that's too much of a change. I believe Terry changed it's functionality. Please advise... Thank you.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (3Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 65... 20-21psi)
