PrzeChuj PrzeChuj is offline
Car: 08 335i
Default On3 single turbo build - 02-17-2019, 11:01 AM
Just wanted to share my single turbo build. With the price on3 is asking and the factory twins blowing smoke like a diesel i needed to do something. Cost was my biggest decision maker. As the reviews of others I have seen , the kit is great quality, to be seen on the turbo but i have no plans of pushing more then 24psi
. Currently the car is out of order , i blew a transistor in the DME. Will be delivered tomorrow so I get to put my SMD skills to use. I'm running full E85 , two walbros in the tank and meth. I have a custom dual catch can setup with external pcv. Except for AD fittings and two ecs catch can I plumbed it all in -10an . I been getting good reviews from people on the streets doen here in Florida so I wanted to share it with you and maybe help somebody out. On3 kit fit with no issues I got the twins out in about 9 hours in my driveway.
Took a bit over 16 hours putting it back together but i changed the oil pan gasket and spent time scrubbing the subframe and cleaning all the exposed realstate with the twins out. I making about 7.5 psi on wastegate and pulled a few on 20psi , everything is humming better then expected untill the slight delay on the DME
. I'm running a VW expansion tank $6 from local junk yard. Had it on there with the twins and does the job so if anyone is having expansion tank problems, this is a great and cost effective option.
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
brainstormubu's Avatar
brainstormubu brainstormubu is offline
Car: 2010 BMW 135i
Default 02-17-2019, 11:31 AM
What up E. Sick build!!! Can't wait to ride in it once the minor issue is fixed. Amazed at the engine bay everytime you pop the hood. N54GANG4LIFE
e82 MT 2010
stock twins
FBO
Single 450 lpfp
E60
JB4 w/pump and e85 BEF
Car: 08 335i
Default 02-17-2019, 12:11 PM
Good to finally find you on here, get your self situated so we can back to work on yours.
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
Ancient8989's Avatar
Ancient8989 Ancient8989 is offline
Default 02-17-2019, 06:15 PM
Glad to see more on3 kits out there. My buddy and I run them. Mine RWD and his AWD we got the kit to fit his car with no modifications. Nice build.
Car: 08 335i
Default 02-17-2019, 06:49 PM
Thanks I was really surprised how well it went together. Near future I will get a stronger wastegate spring but for now I happy with the results. Also plan on extending and moving the wiring to the firewall instead over the ********. Four days to receive the kit is also a plus for anyone in a hurry.
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
Default 02-17-2019, 08:31 PM
Were you able to use the coupler they sent for the turbo to the hotside? I had to get a longer one.
Car: 08 335i
Default 02-18-2019, 06:04 AM
Coupler was the right size for me , I replaced ******** v band, it gave me a bit of trouble trying to take it off
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
Default 02-20-2019, 10:02 AM
The on3 manifold always looks so tiny haha
Car: 08 335i
Default 02-20-2019, 11:38 AM
Thank you for that information.
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
