Car: 2019 Q50 Luxe
02-16-2019, 02:02 PM
BMS intakes installed today. Nice to hear the turbo spools and whoosh when you let off the gas. Dyno in 6 days. Back to 93 for now but will be on e30 for my appointment. Hoping for 415 whp, 410 minimum.
12.64 @114mph
0-60 4.46
02-16-2019, 03:17 PM
If it's a fair reading dynojet you should hit it!
Car: Q50
newb -
02-16-2019, 06:02 PM
new here, recently installed JB4. First, why does my gear indicator always show 0. Second, how do my logs look? Thanks
Car: q50
02-17-2019, 11:56 AM
what version firmware? trans temp didn't show up so must be old? Boost and timing looked fine. You should consider the fuel wire upgrade.
Car: Q50
02-17-2019, 06:27 PM
I'm guessing Rev 3.6?
02-17-2019, 06:31 PM
Log looks good to me but it's older v2 firmware. Gear isn't currently logging, road speed is there though.
Car: 2017 Q60 Luxe
02-17-2019, 06:43 PM
My logs always show 0 for gear, I'm using FW version 7.
Car: Q50
ok so i need to update to JB4_VR30_7.hex on post #2?
02-17-2019, 07:00 PM
Yes - V7 is the latest - number of notable improvements
2017 Q50 Premium RWD - BMS JB4 w/ Fuel Wires
- BMS WMI w/ PM8’s
- Pure Stage 2 Turbos
- Z1 PU Motor Mounts
- AMS HX w/ Aux Tank & IC Pump
- AMS HPFP (RA338) & LPFP
- AMS Flex Fuel Kit v2
- AMS LDP
- AMS CAI
- Fast Intentions Res. Touring 2.5” CBE
- Mishimoto Oil Catch Can
- EcuTek Flash (Seb @ Specialty Z)
Car: q50
Yes, if you're on firmware 2 there's quite a bit more features now including fixes in some of the logging functions.
Car: Q50
02-17-2019, 07:04 PM
thanks guys, i will give it a try!
Car: 2018 INFINITI Q50 Silver Sport 3.0TT
BMS Stage 1 Adjustment -
02-18-2019, 08:30 PM
Hello everyone!
I just got my hands on a BMS Stage 1 for my 2018 Q50 Silver Sport. From what I understand from the description of the product, the default map comes +3psi over stock but can be adjusted via the BMS Data Cable. Is there a link with instructions on how to adjust it? Or can someone help me out? I have the JB4 Software installed already.
Thanks!!!
Bryan
02-18-2019, 08:59 PM
First post has all the details.
02-18-2019, 09:09 PM
OMG....how did I miss that...I guess I was too excited to get it on my car!
Once I select Map 3 and make the adjustments, do I just exit the program and Map 3 becomes the active? Thanks Terry
02-18-2019, 09:42 PM
after you click "save" it should be.
Car: 2016 Q50
02-19-2019, 06:06 PM
Can the BMS data cable hard wired software be downloaded on Android OS tablets? I currently have it on my Mac but I want to have a device with me at all times so it’s easier to change maps and such. What’s the requirements other than a USB in order to have the JB4 desktop app installed
02-19-2019, 06:10 PM
Yes, with an OTG you can use JB4 Mobile (phone app) with the BMS data cable instead of the blue tooth adapter. It's an app side setting.
For the windows interface anything will do as long as it has a USB port and windows.
Car: 2017 Q60 Premium AWD
02-20-2019, 10:16 AM
Terry,
I bumped up my Stage 1 to +7 on my 2017 Q60 AWD Premium on 93 and it is running great without any issues for about 3 weeks now. Is it safe to go higher, or is there a point of diminishing returns?
02-20-2019, 10:26 AM
Originally Posted by Q60NH
Terry,
Post up a log so we can take a look.
02-20-2019, 10:49 AM
I'm running Stage 1 so I'm not able to generate logs.
02-20-2019, 10:55 AM
Terry,
You're really flying blind doing that on Stage1. I wouldn't suggest it.
Car: q50
02-20-2019, 01:36 PM
Seems silly to turn the boost up at all without being able to log the parameters to see if everything is good. Basically hoping and guessing and that's it.
Car: Q50 Red Sport
02-20-2019, 06:53 PM
The upgrade is cheap and well worth it! I highly recommend it.
Car: Q50
02-21-2019, 08:19 PM
Is there a comprehensive post about turning up the boost/tuning on map 6?
Car: 2019 Q50 Luxe
02-22-2019, 02:45 PM
JB4 Q50 On The Dyno - YouTube
2019 Q50 Luxe RWD
Burger Motorsports JB4
Burger Motorsports Intakes
Burger Motorsports Fuel Wires
E30
Dyno #s: 423 rwHP 450 rwTQ on Map 6
12.64 @114mph
0-60 4.46
