Car: 2014 X1 35i
10-31-2018, 04:22 PM
Had a chance to drive the X1 today, so I tried DWP=0, but I got the 3166 after about 5 miles. Cleared it, drove another 10 miles, checked codes and it was back again.
Any other settings to experiment with?
10-31-2018, 04:33 PM
Put DWP back then, and put the brown MAP sensor patch to stock. That seems to be the best resolution.
Car: 2014 X1 35i
10-31-2018, 05:45 PM
Ok - I get the CEL about as much either way. Thanks for the help Terry  .
Car: bmw x1
11-01-2018, 06:55 AM
MrHaloHalo,
Do you get 3166 on Map 0?
I've had DWP=0 for a day now and so far no code. Keeping my fingers crossed.
Car: 2014 X1 35i
11-01-2018, 10:34 AM
A while ago I tried Map0 for a few hundred miles and 3166 did not appear.
Do you have the JB4 connected to the MAP sensor?
Car: bmw x1
11-01-2018, 05:05 PM
Yes, my jb4 is connected to the MAP. I hadnt tried it connected to stock yet. Thought i would try DWP=0 first
Car: bmw x1
11-03-2018, 04:34 AM
So no 3166 code with DWP=0 in JB4 Mobile with MAP connected to the JB4 harness, after 3-4 days of driving now. Unfortunately the turbo lag is noticeable with this setting. May try to up the value gradually to see what works without that 3166 code popping up.
Thanks Terry!
Car: bmw x1
11-14-2018, 04:23 PM
So I've gone back to DWP=60 (default). Periodically, I will just clear the 3166 code. I just don't like the driveability of the car on DWP=0 and higher values seem to trigger the code.
Maybe if there's a warm up, I'll try pluggin in the MAP back to stock.
11-14-2018, 05:28 PM
Good intel never-the-less. If I know it's related to DWP I can make tuning adjustments for it.
Post a JB4 log of you cruising at mid throttle if you can so I can evaluate.
Car: 2013 335
11-14-2018, 06:23 PM
Updated the FW, disconnected the MAP, no more MIL.
If you want me to run a log with the MAP plugged in lmk.
I’d guess having the map unplugged isn’t ideal
For what it’s worth, I drove it for weeks without a MIL when driving lightly. It’s when I really go on it the MIL came on
Car: 2012 135i N55 DCT
11-14-2018, 08:09 PM
For my car MAP unplugged and default wastegate position at 60 is running great, no codes and no lag aside from my 7.5in fmic.
Car: E93
01-15-2019, 12:26 PM
Hopefully this isn't a necrothread. But since I started it I'll give it a jump start. Hadn't posted anything as I diagnosed the car with a bad PCV and didn't want to blame the JB4 until the car was fixed. I'd see 3166 codes about every 50-100 miles and sometimes even the dreaded "half engine" warning would appear. Had run the car with MAP 0 for months with out any CEL while I got around to replacing the valve cover.
For more info - what prompted me to think the PCV was bad was that under braking the car would sometimes make a chirping noise (kind of sounded like brake squeal but evidently a bad PCV on the N55 causes air to be pulled past the front and rear main seals making this chirp/whistle sound). With MAP 5 it would happen fairly frequently. On MAP 0 barely ever would you hear it.
Last week replaced the valve cover, switched over to MAP 5 and within 50 miles the 3166 code was back. Cleared the code and started a log for a few minutes of drive time at multiple throttle settings. That log is attached. 3166 code came back after about another 50 miles. cleared it and now back to map 0. If I can't figure out what is wrong the JB4 will come out as it's kind of pointless as it's my wife's car and she doesn't need to deal with random CEL.
01-15-2019, 12:40 PM
3166 code has nothing to do with the PCV valve, I had luck unplugging the MAP connection on the intake manifold and putting the stock one back in, leaving the rest of the JB4 connections plugged in. If all the codes that this little piggyback randomly throws bothers you so much (which it did to me), I would go MHD flash only and deal with a simpler, smoother system.
Car: 2011 e92 335i
01-15-2019, 12:41 PM
Thank you for posting a log. I hope we can find a resolution for this issue.
01-15-2019, 01:05 PM
Did you follow the guidelines to put the brown manifold connector to stock for cars that experience this false alarm fault code?
Car: 2013 135i
01-15-2019, 05:28 PM
Im in the same boat, when I switched the connection back to stock I got a 28A0 code every time I started the car. I would clear it and it would come back randomly as I drove. I switched back to the JB4 being connected and now get the 3166 randomly but much less often then the 28A0. The 3166 code is accompanied by a 387f, and two tuner codes (2C90, 2774) now every time my SES light comes on, which will happen in every map except 0.
2013 135i DCT, 16k miles, BMS Intake/OCC, JB4, ETS 7" IC/CP, AR Down Pipe, GFB DV+, Berk Street Catback, 92/93 oct. - Totaled
2013 135is DCT, 46k miles, BMS Intake, JB4 w/ connect kit, ER CP, VRSF Down pipe, 92/93 oct.
Reason: Add tuner codes.
Car: E93
01-16-2019, 01:55 PM
When I posted this thread I don't think anyone said to disconnect the brown (is the brown MAP) to stock. Maybe I missed it. Kind of assumed the MAP sensor was needed for the JB4 to work at full potential.
Current configuration is all JB4 connectors attached EXCEPT the fuel pressure connector as it was optional as per http://www.burgertuning.com/instructions/n55_stage1.pdf
I'll give that a shot when I have time to get to it. I think just need to pull the air box to get to it. thanks
Car: E93
01-16-2019, 02:02 PM
Whether it does or doesn't have anything to do with the PCV valve - anecdotally when in MAP 5 the chirp/whistle happened frequently and when in MAP 0 nearly never. I didn't want to blame the JB4 for the 3166 code until I knew the car was properly repaired.
One of the issues of random codes is that if you have to continually clear codes the OBDII readiness state gets reset. Which if you have to get a smog check not having the readiness codes set results in a fail. Thanks for the tip. I'd like to get the JB4 working properly as I hate to think I wasted 4 hours installing it
Car: bmw x1
03-19-2019, 05:24 AM
I think it most certainly is the JB4. I ran Map 0 all through winter. No 3166 code at all. After switching back to Map 5, it shows up after a few days.
03-19-2019, 08:44 AM
With brown MAP connection to stock?
Car: E93
03-19-2019, 05:46 PM
Once again posting to my necro thread - apologies but it's the wife's car so I don't get to drive it much. - Finally got around to disconnecting the MAP to stock. Ran it in MAP0 for a while and then went to MAP 5 about middle of February. Good news is the 3166 went away. Bad news is now getting 387F all the time and also the 2C90, 28A0, 36C9 and sometimes the dreaded half engine light and the 2C57 reduced power mode/ boost disable. The SES light rarely comes on. It wasn't even on when the half engine light was one.
This past weekend I had the opportunity to take it out for drive. Went WOT on an on ramp and right as I'm getting ready to merge into some traffic car just feels like it hit a brick wall and loses power, half engine light is on and luckily the guy I was trying to merge in front of didn't plow into the back of the car. Pulled over and turned off car. Restarted and half engine light on. Stopped engine, removed key. Then restarted and half engine light gone. had 28A0, 2C90, 387F, and 2C57 codes in memory. I did not clear them. No SES. Drove the car hard on the way back home. Some logs attached. Next day was nice and my daughter wanted to drive the car as it was nice she wanted to have the top down. I switched the tune to map 0. She calls about 30 minutes later and says Idrive display says reduced power mode and there is a "weird light" on the dash (the half engine light). I tell her to stop and restart it. Clears the light. When she got home I cleared all the codes. Today I drove the car with no problems but 387F and 2C90 are showing as a code - no SES. I took a log of today also - attached. Really not sure at this point what to do next with this. I could just drive it around in MAP 0 when I'm not driving it but seems a bit pointless having a JB4 to drive it with the stock map 90% of the time. Plus with those pending codes I have no idea if the OBD readiness ever makes it set which will be a problem when its time to smog the car. Any suggestions?
Car: bmw x1
03-24-2019, 03:06 PM
Haven't tried that yet. Was hesistant because other got a different code and more frequently. Will do that and report back.
Car: E93
03-25-2019, 03:53 PM
Bump
03-25-2019, 06:03 PM
Just getting back to this. Yes driving around in map0 isn't a good long term solution at all.
OK so with everything connected and on map1, the only code that triggers now is 3166?
What is menu12 set to in dash?
