Upvcstore Upvcstore is offline
Car: M140I
Default M140I MANUAL LOG REVIEWS - 12-27-2018, 09:20 AM
Hi Guys,
Wonder if I can have some help here? New to the logs thing so I apologise if I have done something wrong.
Car keeps having loss of power at complete random times. Sometimes feels brilliant but other times feels like it has no boost even though the logs are showing it has then hits around 4/5k rpm and it goes to normal. Probably worth noting the most common is when changing up from 2nd to 3rd, seems to be the main culprit.
Happened on previous firmware and also on latest.
Tried putting these logs on to see if anyone can identify any issues. Be great if someone can help as car feels great but getting worried something could be wrong.
Any guidance would be very appreciated
Default 12-27-2018, 11:12 AM
These logs look pretty good actually. You're hitting more than stock is requesting so JB4 is working. Not really sure about the loss of power . Can you try and get me a log on map 0 and see if it does the same?
What fuel are you using?
Car: M140I
Default Extra Logs - 12-27-2018, 12:14 PM
Thankyou for getting back to me quickly. To Try help find out what is wrong I have just been out and redone 5 logs.
I have put a little description at the end to say if the car pulled fine or not.
On the ones that say "Is this one Odd", on one of those the car seemed to pull very weak until about 4/5k and then seemed to pick up straight away. Only reason I do not know which one is due to me not knowing if it autlogged again
Really hoping you can find something that could be causing this as the issue is getting more and more frequent and I have no idea what is causing it. I have experienced this power issue on MAPS 1 through to 3 it just happens this one happened on three this time
When the car pulls normal it pulls extremely well, I came from a Stage 2 A45 and this feels so much stronger so really hoping I can resolve this.
Also I literally live next to a Shell Petrol Station and the car has always used Shell 99 Vpower? Is this enough to sustain the MAPS?
Car: M140I
Default Forgot This One - 12-27-2018, 12:18 PM
Sorry this was the MAP 3 pull I did just before the error one I have stated. Forgot to upload this
File Type: csv 2018-12-27 18_47_52 Map-3 () Car Pulled Fine.csv (8.7 KB, 83 views)
Car: M140I
Default 01-03-2019, 02:25 PM
Don’t suppose anyone got chance to look through these and have any suggestions? Since these the car is now developing throttle closure issues ?
Thanks for your help
