Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default Single turbo catch can discussion. - 09-02-2016, 06:25 AM
I have been reading threads all morning. Exhausting and confusing. I am running an fftec 6466. I only have the rb valve and no catch can. I am wanting to get a catch can and possible vta all because I Smoke on decel or after sitting in traffic for some time.
From reading I would need to get the AD flapper delete valve and really any can I want, but this all seems confusing to me. People go back and forth and they all say something different. Please single turbo guy point me in the right direction. I'm so over smoking and looking like I drive a busted car
phil1320 phil1320 is offline
Car: 2011 335is
Default 09-02-2016, 06:28 AM
Well from what I read, usually if you are smoking it is a sign of a failed PCV system, or a component of the PCV system. With the RB valve, it is somewhat surprising. I don't know as much as most people on the forum on the catch cans but I do know that you want to at least have something as even with a RB pcv valve, some oil will still make it through. Have you checked the turbo to make sure it doesn't have a bad seal?
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 09-02-2016, 06:37 AM
Hey bud I'm running a fftec 6466 car too. I have a RB external PCV. I have a hose routed from the flapper to the filter on the turbo and Mishimoto catch can. Look at the RB external PCV thread. There is a diy posted there.
Car: 2007 BMW 335i
If you want to VTA then don't run a hose to the filter just let it vent.
Bme30's Avatar
Default 09-02-2016, 06:39 AM
I am running the RB valve currently. I don't believe it is the turbo, because the car doesn't smoke large volumes or all the time, it is more or less a 50/50 scenario. Sometimes after sitting in stop and go traffic, but not always and also on decel, but again not always. The way the fftec setup it, the the PCV hose goes directly into the filter.
Bme30's Avatar
Default 09-02-2016, 06:40 AM
Thank you ms335i. Did you have any smoking before the catch can or now???
Daily Three Daily Three is offline
Default 09-02-2016, 07:29 AM
Are you certain it is the PCV? Check your turbo first.. Could have a leak at the oil feed or the return.
Bme30's Avatar
Default 09-02-2016, 07:44 AM
I'm certain. No oil leak at the feed or return. And no excessive oil consumption. The oil consumption. Has been the same from 0 miles to now at 65k miles
Bme30's Avatar
Default 09-02-2016, 07:46 AM
Also pulled the Dp and its clean minus the normal carbon buildup.
Default 09-02-2016, 08:02 AM
With a single turbo normally when you're smoking it means the engine is smoked. But in terms of the OCC routing it's the same as stock. Outlet needs to go around to the turbo filter inlet to avoid vapor/odor/illegal configuration. The OCC catches any oil so there is no performance drop doing that.
Bme30's Avatar
Default 09-02-2016, 08:06 AM
Thanks Terry. Again it's not large clouds of smoke or all the time. It just happens from time to time. And it's very little. I can smell it more than I actually see it.
Xshadows Xshadows is offline
Car: 2008 135i
Default 09-02-2016, 10:02 AM
AD-E fittings or the external RB setup both seem to resolve the issue. I think I'm just going to spend the money and order the AD-E catch can and fittings for my setup.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
Car: 2007 BMW 335i
Default 09-02-2016, 12:32 PM
I had smoking before but I don't now. No oil consumption either.
08_335i 08_335i is offline
Car: 2008 335i
Default 09-02-2016, 12:36 PM
Make sure you're running the proper restrictor for your turbo first off. Secondly, run the BMS OCC system on the high side, hose from turbo filter, to OCC, to flapper valve. And lastly, get the RB low side PCV system. If you still smoke after all of that, your motor has issues.
Mario54's Avatar
Mario54 Mario54 is offline
Car: 2008 E90 335i
Default 09-02-2016, 01:58 PM
Thanks OP as I've been looking for what's the best catchcan setup for single Turbo conversions!
Subscribed
Bme30's Avatar
Default 09-02-2016, 03:17 PM
08 335i I have the 6466 gen 2, according to precision the turbo is already restricted and was advised not to restrict any further. Secondly. I honestly do not want 2 separate catch cans in the car....as the clutter to me look distasteless. I'm sure there would be much better ways or just a single option to help elevate these issues.
Bme30's Avatar
Default 09-02-2016, 03:22 PM
As for the motor.....it's not the motor. I really feel It is the pcv system. The motor has been compression tested and the numbers are perfect. I'm just trying to figure out the best occ setup and what has worked for others. I highly doubt I'm the only one that has been here.
R.G. R.G. is offline
Default 09-03-2016, 01:23 AM
First thing I'd check is turbo oil restricter and turbo drain line. If it's not draining well you'll smoke. Too much oil and you'll smoke.
Good luck finding a pcv set up that is generally accepted throughout community other then the head plug and delete. Best thing to do is try to understand the system as well as possible and proceed in a way that would work best for your power goal.
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 09-03-2016, 07:19 AM
We've sold over 100 of our RB external PCV kits over the past year and everyone seems to love them. Many types of turbo setups have said smoking has been mitigated or eliminated once installed, some of which even have came over from an "eliminated PCV" setup. Several smaller shops order them as standard maintenance now, understanding the intent of the function along with the perks they want to ensure it is done on everything they service.
IMO this is the best way to rule out PCV vulnerabilities and gives a sure fire way of collecting all low load PCV muck otherwise destined for the intake valves (or burnt through the chamber and out the exhaust).
I'd suggest reading this thread for a lot of information:
http://www.n54tech.com/forums/showthread.php?t=35535
Thanks,
Rob
Car: 2008 335i
Default 09-03-2016, 08:40 AM
Engine bay "clutter" vs healthy running, what's more important to you?
ncat10 ncat10 is offline
Car: 335
Default 09-03-2016, 11:52 AM
There is my setup. It works perfect. Haven't got any issues with smoke so far.
Bigs135's Avatar
Bigs135 Bigs135 is offline
Default OCC Routing? - 12-24-2018, 02:14 PM
Hey Terry, I am confused on where to exactly locate the other line from oil catch can. I have the line going from pcv valve to oil catch can but where does the other line go exactly? Where do you tap into the turbo filter?
Default 12-24-2018, 03:44 PM
How you set it up depends on the filter. In a fitting on the inlet pipe for bottom mount kits. For top mount kits in the tip of the filter, or even just in the general vicinity of the filter is "good enough".
PrzeChuj PrzeChuj is offline
Car: 08 335i
Default 12-24-2018, 10:18 PM
Just finished my dual check valve setup for pcv . With matching ccv
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
Car: 08 335i
Default 12-24-2018, 10:23 PM
Might help somebody
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
