Woode30 Woode30 is offline
Car: 2008 e92 335i
Default Need a little help with BMS meth kit install. - 12-17-2018, 08:35 PM
I know I know, there’s a million of threads and info on this topic but, I’ve had nothing but problems trying to get my used meth kit working. I’ll keep it short, I finally got it to work a few times. I did some data logs and found that it is not coming on. Checked all my wiring, all wiring is good. The issue is I found the small 3 amp fuse blew in the FSB. I replaced it with an5 amp fuse and the light comes on but I am unable to get the pump to come on in menu 7/5.
Any ideas and help would be great.
Default 12-18-2018, 11:10 AM
Sounds like bad FSB
Car: 2008 e92 335i
Default 12-18-2018, 11:15 AM
Sounds like bad FSB
Payam, thanks for your input. That's what I was afraid of. Is it possible to pick one up at the shop? I'm in LA midcity area.
Default 12-18-2018, 11:35 AM
Just to add, if you are using a non-BMS solenoid it can pull too much current for the V1 FSB to handle. The V2 FSB is a little better. On FSB you can pickup as office if you need, they have a race use only waiver form for it.
Car: 2008 e92 335i
Default 12-18-2018, 11:45 AM
I''m pretty sure its a BMS solenoid, appears to be the same as the website. Ill try and get up there during the week, thank you guys.
