(#2576)
Default 09-01-2018, 09:37 AM
Originally Posted by vtn86
Hi, newer to the platform and forums here. Posted in another forum and was suggested to come over this direction as there is more traffic. Running Map 1 and having an AFR issue. When I first got the JB4, I was told it was already modified ISO, but turns out it wasn't; had an overboosting issue. Now that that's been addressed, settings are standard, and using the most updated firmware, I'm still getting some significant AFR issues. Below is a log, any advice or guidance would be greatly appreciated! Thanks in advance.
/u/vtn86/log-1535604203?log=0&data=1-4
I assume I can't post links since I'm new...the string above is everything after datazap (dot) me.
We don't use datazap. You attach the JB4 CSV file to the post directly.
kyloo kyloo is offline
Car: BMW 135i
Default 09-01-2018, 05:04 PM
Let's see a short log so we can see what is going on there!
Here is a 4th gear pull still overboosting - but 2nd gear peaks around 21psi
Default 09-01-2018, 09:36 PM
I think you have that backwards. It's under boosting. Probably due to the lower FF and duty bias settings. Need the hybrid turbo duty bias upward slope...
Car: BMW 135i
Default 09-02-2018, 01:16 AM
Well initially its overboosting because surely map 2 shouldn't be hitting almost 20psi? Then tapering down to below 10psi
What should I do?
My car is stock turbo. Running the PPK, ********, intake, chargepipe, Jb4, N20 Tmap sensor, Walbro 450 LPFP. I have removed the BEF since the log due to the car not feeling right. Throttle was also very jumpy
Default 09-02-2018, 10:13 AM
You're just reading the log wrong. You can see the target is 19psi there right in the log. If boost was going substantially over target and staying there you'd have an over boost situation. You have an under boost situation.
Map2 with a BEF and/or 3.5bar TMAP sensor is 19psi peak with a strong taper to redline.
For stock turbo turn FUD to 0, so you get the stock turbo duty bias profile at duty bias = 50 across the board, reload the BEF, and relog. Map1 if you prefer.
Car: BMW 135i
Default 09-02-2018, 02:28 PM
Okau I understand
Let me reload the BEF and get a log done and then will post it back here again and have a look
prime300's Avatar
prime300 prime300 is offline
Car: E90 335i xDrive N55
Default 09-23-2018, 04:41 PM
went 1/2 mile racing today , did 126mph on map5 and 123mph on map0...is it normal !? only 3mph with jb4 ??
im running 94 oct,M performance exhaust,charge pipe and kaatl3ss deepee
Paul C.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-23-2018, 04:47 PM
Probably high IATs pulling timing. Did you log the runs? If so post them up in the support section.
Default 09-24-2018, 06:01 AM
Need logs to see what's going on and why.
prime300's Avatar
Default 09-24-2018, 02:55 PM
log attached
Paul C.
Car: 2011 e92 335i
Default 09-24-2018, 03:11 PM
log attached
Be sure to put support questions in the support section.
As I suspected the IATs were really high. The fuel you were using probably isn't great for 15 psi either. Timing was pulled and the car started running pretty rich. I assume the computer does that to cool the IATs and save the engine. If you want to do longer WOT pulls I would upgrade the intercooler and add methanol injection.
JKurello JKurello is offline
Default 09-29-2018, 07:20 AM
Since I've done the N55_ISO_5_17_T5.hex update, whenever the car is ice cold ( like sitting over night) I get a "service engine soon " light on start up. I check and clear the codes and it happens again the next day. Any suggestions?
Same codes each time:
3106 ******* ******** installed
387F
2C90 Blow-off valve mechanics --ignore tuner code
2011 e90 335i VSFR charge pipe, ******* down pipe and BMS CAI
WeekendWarriorz WeekendWarriorz is offline
Car: 2012 135i N55 DCT
Default 09-29-2018, 09:41 PM
Hey Terry, recommended by Ando was to unplug the MAP connection with the latest firmware, which has successfully made the 3166 tank safety ventilation code disappear on my late E series N55. Seems like that’s the fix as a few others I’ve talked too have had the same results!
Default 10-01-2018, 02:51 PM
387F
Youíre running a ******* ******** which the JB4 doesnít clear the codes for
2012 BMW 135i DCT, Late E series. VRSF meowless, ARM chargepipe, VRSF 7.5in race FMIC, Fuel it! Stage 2 LPFP- Sold
Default 10-04-2018, 05:16 AM
Will the JB4 4/4 flash only option still allow the JB4 to control PI and Meth?
jeanson jeanson is offline
Car: F10 535i
Default 10-24-2018, 04:39 AM
hi, I have a friend who has the following question: He has a JB4 box, on the board is "JB4_N55 Rev 2.0" ... is the box for the E or F series? PWG or EWG?
Many Thanks
ingibanez ingibanez is offline
Car: 135i Coupe 2012 E82
Default 11-02-2018, 02:40 PM
Hi I am Patricio from Chile. I have my E82 2012 with JB4 and when i want to set the fuel open loop to 60, I can't. The JB4 write 0 everytime. Can you help me whit this please!
Immaculate Immaculate is offline
Car: 11' 135i
Default 11-02-2018, 02:47 PM
Are you saving the settings after you set it? Iíve done that a couple times where I forget to hit save.
ckanderson ckanderson is offline
Car: 2013 335
Default 11-13-2018, 03:19 PM
Originally Posted by WeekendWarriorz
Hey Terry, recommended by Ando was to unplug the MAP connection with the latest firmware, which has successfully made the 3166 tank safety ventilation code disappear on my late E series N55. Seems like thatís the fix as a few others Iíve talked too have had the same results!
Can you tell me more about this? I have this code too
Default 11-13-2018, 03:21 PM
Update latest firmware, unplug the MAP sensor connector and plug in the stock one.
Car: 2013 335
Default 11-13-2018, 03:40 PM
Done. Thank you!
Car: 2013 N55 135is
Default 11-13-2018, 04:37 PM
I don't understand. I've updated JB4 latest FW already. You're saying I should plug the stock TMAP connector in and then update the FW? Once updated, plug the JB4 TMAP connecter back in like normal?
Default 11-13-2018, 04:40 PM
No, the MAP connection on the intake manifold. Unplug it and put the stock one in.
Car: 2013 N55 135is
Default 11-13-2018, 05:26 PM
Gotcha.
Unplug MAP connection (JB4), plug in stock MAP connection.
Run FW update on JB4
Restore original JB4 connection
I wonder if this is part of my issues.
Car: 2013 335
Default 11-13-2018, 05:29 PM
Gotcha.
noooooo
Unplug the JB4 map connector, plug in factory and leave it like that. also do the FW update.
Did that to mine tonight to get rid of the 3166 code.
