(#976)
Stung Stung is offline
Car: 2018 Kia Stinger GT2 3.3TT
Default 11-07-2018, 04:18 PM
Originally Posted by icecoldak
Make sure you have the latest update for your JB4---you can do that thru the App!
Firmware? Yes, forgot to mention I did that. Thanks, will edit my post.
oddball oddball is offline
Car: 2018 Stinger 3.3L, 1972 Cutlass 403, 2002 Lincoln LS 3.9L
Default 11-08-2018, 08:01 AM
Terry - two feature requests:
1) a true MAP gauge (not just boost). I like tracking vacuum levels too. It's the old school engine builder in me.
2) Changing the tuning map based on time or engine condition. e.g., start on map 0 while the engine warms up, then switch to desired map after the engine is warm. Basically just prevent one from hurting themselves. :D
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 11-08-2018, 08:21 AM
Originally Posted by Stung
Anything else I should be doing to get this dialed in? Or just enjoy Maps 1&2 (sometimes 3 when I dump a few gallons of e85 in)
Some have been running map 3 with healthy 93 octane without issues. With a few gallons of E85 (to make an E30 mix) you should be running map 5.
Default 11-08-2018, 10:28 AM
Warmup protection is already built in, boost is stock until water temp is > 170F. We'll expand that to include oil temperature soon.
Default 11-08-2018, 10:34 AM
Awesome! And MAP gauge?
icecoldak's Avatar
icecoldak icecoldak is offline
Car: 2018 F-150 Limited
Default 11-08-2018, 10:57 AM
Does this pertain to ALL manufacture platforms of the JB4 you offer?
Default 11-08-2018, 12:14 PM
We generally include a warmup safety in all JB4 offerings, but there can be application specific variations so you'd want to ask in the specific thread of the JB4 you run.
Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default Engine check light - 11-09-2018, 08:46 PM
Since Terry isn't allowed, im sure someone else can, how do I get rid of a check engine light with my car, I installed the hatless ********* and I have the two codes that are thrown with it, theres nothing wrong with the car, but id rather not stare at these everyday, I tried to set the fuse D to 90 (youtube video on a MK7 with the same problem) but I need help, thanks!
Car: Stinger
Default 11-09-2018, 09:06 PM
Are you in the US? Do you use Android phone? You might be able to root the phone and set region to non us then use the jb4 code suppression settings
Default 11-09-2018, 09:19 PM
yes im in the states, im in florida actually, we have no emission tests, no I have an iPhone
Default 11-09-2018, 09:33 PM
what are the code suppression settings
Car: Stinger
Default 11-10-2018, 12:12 PM
Under the wmi settings there is a "passive delete" button. On non is regions that sets the code deleted for *** inefficiency. Not available on us due to CARB certification
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 11-10-2018, 06:36 PM
Finally got the JB4 installed with fuel wires. Haven't raised above map1 yet, wanted to play it safe and make sure I didn't leave anything unplugged or unhooked after that ridiculous spark plug swap..... I've owned a lot of vehicles and that one wins the all-time difficulty award.
How do things look?
Default 11-10-2018, 07:50 PM
We had our Stinger out representing today at NFZ. Will link in some videos here soon.
Default 11-10-2018, 07:51 PM
How do things look?
The plug swap is a headache, but once you've done it once it's much easier. Log looks good to me!
Ducaiti999 Ducaiti999 is offline
Car: Kia stinger gt2
Default 11-10-2018, 10:34 PM
How does it run with the deletes? Any smell issues? Any update on the light issue?
Default 11-11-2018, 12:03 PM
Light is still on, quiet frustrating actually, I can’t even use the launch control in the car now due to the engine light, went to the track yesterday and ran a 12.6 due to a good proper launch, really ticked me off, granted it was hot, but For the mods I have .. I should be consistint high 11’s
Yes there’s a smell, only when you’re behind the car or behind me while driving, car is remarkably quicker, but the noise the car makes is S**T, need to figure out how to get rid of the rasp/rice, was thinking about adding the stock mufflers back on but wouldn’t that hurt performance?
Default 11-11-2018, 02:56 PM
Yea I was wondering about the sound. I'm beginning to think it's time to put the breaks on with the mods. At least until bigger turbos are available. I bought this instead of a hellcat so I wouldn't go crazy. Now I have Drone and it only seems like things get worse with the *****'s. I have a sickness and it's nearly impossible for me to leave stuff alone. This happened to me with M car's then on day I decided to stop the BS with FI 6 cylinders and built a high 9 FI V8 street car. That may happen again soon. Lol
icecoldak's Avatar
Default 11-11-2018, 10:14 PM
Just get you a Redeye and be done with it--low 11's with ZERO mods and factory warranty to boot!!
Default 11-11-2018, 10:21 PM
Yea I can see the possibilities. Lol. Problem is it won't stop with stock.
Armadyllo Armadyllo is offline
Car: 335i E90 2008
Default Log Check Thanks - 11-14-2018, 12:40 PM
Hi Terry
Can you please check the attached log to see how the car is holding up on map 3 before I change to map 5.
And can you also check that I have installed the fuel wires correctly.
I'm currently running about 30% E85
Default 11-14-2018, 12:52 PM
Originally Posted by Armadyllo
Hi Terry
Looks normal to me!
Car: 335i E90 2008
Default 11-14-2018, 01:02 PM
Looks normal to me!
Thanks Terry
So the fuel wires and fuel settings are set up correctly ?
Great work with the JB4 the car is and animal
Default 11-14-2018, 02:22 PM
Looks to be, yes. Fuel trims bank to bank match and I see fuel enrichment moving as expected.
Car: 335i E90 2008
Default 11-14-2018, 05:00 PM
Great to here
Thanks Terry
