Car: 535i
07-25-2018, 03:40 PM
can you just get an upgraded Lpfp and e85 mix instead of port injection? not a fan of PI
Car: Bmw 335i ST
07-25-2018, 03:56 PM
why are you saying you are not a fan of pi ,, pi is the most beneficial things you can have for your hp fuel system. having just an upgraded lpfp its not enough if you want to go big. make sure you get someone that knows n wire the p.i properly.. i have heard lot of cases where people are having issues and this is bcause the installer dosnt know how to install it properly n wire it to the dme(jb4)..
fuel it! does offer the best products as far as p.i etc..
Car: 335xi, 335i
07-25-2018, 06:38 PM
Originally Posted by bmweurotuning
you dont redline on stock turbos , after 6krpm stock turbos dont make more pwr. i can achieve 540whp at 21psi w proper fuel pi, meth e85 ...
This means you need to make 473wtq at 6000 rpm to make 540whp...unless you plan to make peak power even earlier.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Car: Bmw 335i ST
07-25-2018, 06:40 PM
I can make more than that at 6k rpm and yes
Car: 335i MSport DCT
07-26-2018, 02:41 AM
what exactly do you recommend to achieve 500rwhp on stock turbos, planning on swapping mine for a brand new stock set
Probably this cos it aint happening.
The most you'll get on stockers with proper fuel is 450whp.
Trust me. Did it on E50 and port meth injection about 2 years ago.
The stock turbos compressor wheels are just too small. I ran 23 psi on them for a long time.
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
07-26-2018, 02:44 AM
The stock lpfp is under gunned, hence the upgraded 450lph versions for stage 2 or stage 2 bucketless but you are feeding a crappy hpfp. You need port injection or meth injection to help it. But don't believe this 540whp story
Car: 335xi, 335i
07-26-2018, 04:58 AM
Then you will make more than 540WHP
Car: Bmw 335i ST
07-26-2018, 08:38 AM
maybe you wernt able to bcause of your set up. and i have done it on full e85 in the past .. maybe you need to get more fuel lets say 3 450 Walbros on your lpfs and on your hp side have pi and double barrell hpfp anything is possible as long as you know what you are doing
Car: Bmw 335i ST
07-26-2018, 08:39 AM
you can have 2 hpfp if you know what you are doing also port injection to conpenssate under wot
Car: Bmw 335i ST
07-26-2018, 08:44 AM
Car: Bmw 335i ST
07-26-2018, 08:45 AM
sure
Car: Bmw 335i ST
07-26-2018, 08:46 AM
sure
Car: 2007 e60 5 series
07-26-2018, 05:10 PM
Well someone knows what's going on out there. This is good hard info about the capacity of stock turbos. This give me hope that stage ones can run at 500whp at a safe level with proper fueling.
07-27-2018, 06:12 AM
6124rpm, 19.4psi with only 54 wgdc. Lulz
07-27-2018, 08:34 AM
The wgdc doesn't mean much. You can screw the wastegate arms in tight to lower the vacuum needed to close them.
The stock turbos are something like 10T TD03s. I think people are wasting their time airming for 500WHP with them. I did around 477WHP in 2016. Like E50 fuel with meth injection. You only need to see the compressor chart to realise it's an uphill battle.
Yes it's just a jb4 log in virtual dyno
Car: 2010 535i m sport wagon
07-27-2018, 09:23 AM
the car is a 2009 bmw 335i 6 speed manual
mods : Jb4,Dci's, Bms BEF, Running e40, New 335is clutch.
3 pulls were made @102f outside temp... after 1 hr run car on dyno again and the outcome was 420hp, 520tq. @ 19.5 psi. i will post new dyno data sheet after couple mods coming up.. it should be around 540hp @22psi. 5xxtq.
You probably shouldn’t of posted that until you actually made it happen. Take it to the drag strip and post those numbers!!
Car: Bmw 335i ST
07-27-2018, 09:40 AM
anyone that knows the potential of this car know what they can do i dont have to prove anyone anything you can watch this video n convince your self . Thats not a car i have worked on myself but anyone that knnows what they are doing can achive the same outcome at the track:
Video here
https://www.youtube.com/watch?v=61u2KIGabZI
Car: 335xi, 335i
07-27-2018, 10:06 AM
HAHAHA I know you are just trolling us now
Car: Bmw 335i ST
07-27-2018, 11:08 AM
07-27-2018, 02:59 PM
Video here
Full retard
Please people. Don't let some idiot sell you a lie and blow up your engine.
Sua Sponte
Car: 13 335is
07-27-2018, 04:48 PM
I knew there was a reason I check in over here every once and a while. You just can't make this stuff up...well most of the time you can't.
 '13 LMB 335is DCT | MHD/BQ Tuning |
Car: Bmw 335i ST
07-27-2018, 05:07 PM
Full retard
none is selling anything. we are posting info thats all if you want to buy anything you can click here:
http://www.burgertuning.com/
and if you need to upgrade your fuel system so you wont blow up your engine you can buy here:
http://www.fuel-it.com/
Car: Bmw 335i ST
07-27-2018, 05:11 PM
Full retard
btw your car needs improevement
if you need more fuel system upgrade you can upgrade here:
07-29-2018, 04:12 AM
Video here
WTF does that video have to do with “YOUR” car making 540whp on stock turbos??? Cmon man stop the nonsense now!!
08-01-2018, 07:09 AM
Lol come on guy. This has to be a joke- very few people have hit 500whp and that was every mod in the world with way to much boost for stokers-glory run.
07 E92 MT RB Turbos-600whp
08 E82 Built engine/trans Speedtech ST 6466
