(#76)
Car: 335i, 2009
Default 06-26-2018, 04:52 PM
hm, maybe someone will chime in with something.. I used the Alpina flash and XHP 3, both have the same problem. Such a weird symptom...
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 06-26-2018, 05:54 PM
Get some clutches from PD , upgrade the valvebody with Sonnax kit , put an oil cooler tranny from Setrab, and change oil with Pentozin AF1.
Car: 335i, 2009
Default 06-27-2018, 09:36 AM
Clutches, maybe. But we don't have satisfying evidence to say that it is specifically the clutches.
Um, no, it does not need the sonnax kit, As I mentioned earlier, I have replaced all the gaskets, and I have replaced all of the solenoids, which made no difference to the performance.
Our cars already a tranny cooler, but I agree they would benefit from a cooler running system. This could already be done if you ran a colder thermostat since the coolant cools the tranny via a heat exchanger. If the failure is mechanical, then the damage is done and a cooler tranny likely wont help. I have read numerous amounts of people changing their fluid with various varieties. I have not seen one of those circumstances fix slipping issues once the car is already in gear.
A likely cause is bushing that is leaking fluid and there just isnt enough pressure to hold the clutch plates together. If the clutches were worn, then I would not expect them to be worn in gears 5 and 6 where those typically see the least wear.
BMS Stage 1
BMW135xi's Avatar
Car: BMW 135I
Default 06-27-2018, 09:44 AM
Than probably worn bushings..
Car: 335i, 2009
Default 06-27-2018, 09:49 AM
probably... gotta pull tranny for that... I'll just live with the issue
BMS Stage 1
BMW135xi's Avatar
Car: BMW 135I
Default 06-27-2018, 10:16 AM
Well , don'y worry this is my third tranny. I buy them in ebay with low mileage for anywhere from $800 to $1,500. Good luck..
Default 06-27-2018, 10:54 AM
Damn man! How you blow so many?
BMW135xi's Avatar
Car: BMW 135I
Default 06-27-2018, 11:06 AM
Keeping the boost to high with pure stage#2 ..
Default 06-27-2018, 11:33 AM
At least you're having fun!
BMW135xi's Avatar
Car: BMW 135I
Default 06-27-2018, 11:38 AM
yep, love the spool at 24 psi and 28 psi .
seroga1986's Avatar
Default 06-28-2018, 08:06 AM
I have logged over 80 on track hours all on 20psi. Thousands of street pulls, drag racing and shenanigans on 23-25psi. Trans is working great, no hickups. I have bypassed the heat exchanger and did my own trans cooler set up with a 160 thermostat. Barely see temps over 170 even on track with 20 min sessions.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
dh58 dh58 is offline
Default 12-08-2018, 08:16 PM
Did you ever get this resolved?
I am now having the exact same issue.. on the same BB E85 flash..
Carlos Carlos is offline
Car: '07 335i Convertible
Talking Trans - 12-10-2018, 09:14 AM
I haven't had this problem yet with my AT, but if time to replace the transmission...., are there any other options aside of a stock new, stock rebuild, or a stock used transmission?
Turbohugh Turbohugh is offline
Car: E90-355I
Default 04-28-2019, 09:38 PM
I'm having the same issue. I think it's the bushing, from youtube and everything else I'm reading this bushing, once worn permits excessive fluid to bypass and that decreases the clamping pressure available to keep the E clutch pack together. This can be temporarily fixed with higher viscosity fluids however it wont be fixed without new bushing and other mechanical part replacements = $$$$$ !
robertsawh82 robertsawh82 is offline
Car: 07 BMW 335i
Default 10-05-2019, 11:54 PM
I have the same problem with my transmission coming out of gear and sticking in first also, not allowing me to shift.
2.5 inch **'s, MMP INLETS, MMP OUTLETS, JB4 PI CONTROLLER, BACKEND FLASH E85, PRECISION RACEWORKS STAGE 3 PLUS PUMPS, n20 tmap, EOS MANIFOLD, Rod Sutphin Trans Tune.
mafia321's Avatar
mafia321 mafia321 is offline
Car: bmw 335
Default 10-08-2019, 04:09 PM
oil temp trans? activate cold fan menu 6 options 1
codesx's Avatar
codesx codesx is offline
Default 10-09-2019, 09:19 AM
+1. Also curious. I'm on my second A/T and when my love of brake boosting, I'm wondering about a potential 3rd A/T. Still working, but our line of Transmissions had a few that were rated higher. Wondering if anyone swapped one of them in. (ZF 6HP --> ZF 8HP)
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 07 BMW 335i
Default 10-09-2019, 01:30 PM
I emailed xhp and they told me it's not a software issue and it's a problem with the hardware. I recently purchased this transmission about two years ago from BMW. So it's a brand new transmission. Not sure of the transmission temperature when it happens. I'll check when it happens again
Car: E90-355I
Default 10-15-2019, 11:53 AM
can you get MHD and datalog the temps ?
What adaptations and fault codes are in your trans? Can you screen shot the XHP report?
Default 10-15-2019, 01:27 PM
Order our BMS trans cooler and get the XHP flash
https://burgertuning.com/products/bm...cf786bbd&_ss=r
msport335 msport335 is offline
Car: E90 LCI
Default 10-25-2019, 12:27 PM
same issue here all season long... N54, PS2, Meth and XHP stage 3.
car will not even hold a 3rd gear pull all the way to redline as it pops itself out of gear and is stuck in 5th. will not downshift automatically when coming to a stop either. i have to manually downshift to 1st or 2nd when moving from a stop after a hard pull.
never had trans serviced and it now has 140k KMS ....unsure whether a service would do it or if i need to upgrade the clutches.
I daily it with just north of 600whp and max it hit on dyno was 670whp
CastleBravo's Avatar
CastleBravo CastleBravo is offline
Car: M135i
Default 11-07-2019, 09:13 PM
I replaced the clutches (and a broken reverse drum) on my 5 HP 19 from my old 330i a few years back. Despite the odd quality issue ZF make great transmissions and they are very diy serviceable if you do your research.
Now the thing is under 'normal use' these clutch packs don't really wear as they are immersed in fluids. My unit had 130k miles on it and didn't really need to replace the clutches according to a AT rebuilder I consulted. As I'd gone to the effort of getting into the thing to replace the broken drum.
High torque and or high fluid temperatures could likely cause wear, however in 'normal use' it seems that the clutch packs wearing out is not the typical cause of failures.
The other cause of course can be in the valve body. I stayed out of the valve body so cannot comment on issues there, however I do know the valve body solenoids are easily replaced.
