lanii00's Avatar
lanii00 lanii00 is offline
Car: bmw 335
Default Which O2 sensor is bad? - 06-01-2018, 02:42 PM
Hello everyone,
I’ve had this issue for quite some time without finding a solution and I’d figure now is the time to fix it. I have replaced my pre-*** o2 sensors not exactly at the same time but they are both fairly new. And no I’m pretty sure they are located in the correct ********* as I know that is a possibility. I still get check engine lights on the car. Here are the codes I get
2C31 Lambda probe in front of catalytic converter, trimming control
2F7B Oil pressure switch, plausibility
29E1 Fuel mixture control 2
Here is the o2 sensor part number of the black wire o2 sensor that I replaced that I believed was the issue. OEM Part #: 11787558055
Why am I still getting codes ? Did I change the wrong O2 sensor? Is it Post *** O2 sensors ?
335i e90 sedan| Cobb catted *** | Muffler Delete | VRSF 5’ stepped intercooler| BMS OCC | BMS dual cone | MMP Inlets | BMS Oil Temp Cooler | JB4 G5 | PureEvilTuning Custom E60 BF | XHP TCU Flash | Phoenix Racing Charge Pipe | Tial BOV | 3.5 Bar | Stock Turbos | NGK 2 Step Spark Plugs (0.020 Gap) | Fuel It Stage 2 | 19psi making 475whp & 528lb tq |
Default 06-01-2018, 03:07 PM
That should be the primary O2 sensor for Bank 1. You could have swapped the wrong O2 sensor more than likely.
lanii00's Avatar
Car: bmw 335
Default 06-01-2018, 03:23 PM
Are you referring to the grey wire one is th bad O2? This part #: 11787558087?
lanii00's Avatar
Car: bmw 335
Default 06-01-2018, 04:40 PM
Could this be due to the amount of E85 vs what the tune reads ?
mj6234 mj6234 is offline
Car: 2008 335i
Default 06-01-2018, 05:06 PM
I had the trimming control code and it was the rear O2 on that bank.
I can't explain it exactly, but there is some sort of interaction between the primary and secondary where the DME validates the readings between the two. I spent a lot of time and money troubleshooting my issue (including replacing the primaries) and it was the secondary all along.
I also had some sort of aging code for the secondary O2 sensor as well, which you don't appear to have.
lanii00's Avatar
Car: bmw 335
Default 06-01-2018, 05:11 PM
By secondary, do you mean post cats? Do you have part numbers by chance? Would this be on the outer ********* I’m guessing?
RSicks's Avatar
RSicks RSicks is offline
Car: 2010 535i M-Sport
Default 06-01-2018, 06:07 PM
I had the same thing, secondary O2 cause the code and cleared once I replaced it.
'15 435i ///M Sport
CTS Intake • VRSF CP/Race FMIC/DP/TIC • MST Inlet • xHP S3 • 3.5 TMAP • Wedge Tune in process
lanii00's Avatar
Car: bmw 335
Default 06-01-2018, 07:14 PM
Thank you! I will go ahead and buy that O2 sensor
AZN54 AZN54 is offline
Car: N54 135i
Default 06-04-2018, 07:49 PM
I had something very similar on bank 2. Replaced pre-*** o2, code remained. Replaced post-*** and cleared it up.
Make sure you reset adaptations after.
2009 135i
DOC Race 6266 Single, VS DW400 LPFP, VRSF Race FMIC, Motiv BoostBox, Tuned by Wedge
Offering Arizona Walnut Blasting Service:
http://www.n54tech.com/forums/showthread.php?t=36741
lanii00's Avatar
Car: bmw 335
Default 06-18-2018, 12:21 PM
Update: Took a while to do this, but changed the secondary O2 and no more codes ! Thank you all !
