04-25-2018, 02:39 PM
torr can you post the csv for that log, hard to read the log with the picture. But it looks like you are still running that thing very lean. I am sure it feels good, but wont that generate a bunch of heat? Maybe that is why the turbo failed.
04-25-2018, 04:58 PM
What, you dont think 2000F+ exhaust gases mixed with a STUPID pre turbine pressure ratio is good for turbo life???
Might want to log with MHD to see more variables.
Like PURE said, this is a pump fighting a pump. The turbofold sucks, PS2 is amazing but turbofold causes inefficencies that cant be overlooked at some point. Consider I made nearly 100 more WHP at same pressure..... EFR 7670 vs PS2. Comes at a cost though, both capex and opex (more of a pain to install). So each needs to make there own call.
If I wanted more than 500 WHP, or if I wanted to daily at this level, I would ONLY go with one of the stage 3 options.
I am waiting for someone to take a PS2 for B58 and adapt to N55 with OEM hardware. To me this would be pretty close to the stage 3 products. B58 turbofold and turbo is MUCH better.
Car: 2011 335i
04-26-2018, 10:01 AM
I was wrong, Sorry for the confusion.
The turbo is still perfect and the problem was a broken rod.
I am aware I was pushing it way to far and I guess that my favorite thing to do is tear my car apart.
Props to Pure on their stage 2, it is able to run up to 35 PSI.
2011 335i E92 AT, JB4, FMIC, DP, CP. Pure stg2 w/high flow intake & DV+. Fuel-It! E85 BEF Flash, stg2 LPFP & PI.
Car: 2011 BMW E92
04-26-2018, 10:19 AM
Those Pure stg2's are tough but 35psi
Anyway, welcome to club! LOL
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
Car: 2011 335xi
04-26-2018, 11:04 AM
Originally Posted by Newguy123
FYI, dual 2.5" pi pes is the exact same area as a single 3.5" that the supra made 600+whp on...
04-26-2018, 11:05 AM
Lol. Daym, you put the hw though the ringer, that’s for sure! So what’s your plan, stick bottom end again?
Btw, appreciate you coming back and posting updates. Always nice to know how things end up.
04-26-2018, 11:08 AM
Your car is dual 2.5”. He is referring to the 1er that goes from duals to a single 2.5” at the y pipe. We are going from the two duals to a 3.5” single for the 1er. Made a big difference for us.
Car: 2011 335i
04-26-2018, 01:40 PM
It will be a engine swap.
Here is the log .csv
04-26-2018, 02:06 PM
Bummer. Well, glad at least the turbo's OK! Thanks for letting us know!
04-26-2018, 02:38 PM
Your afr doesn't look bad at all in that log. 12.6 to 12.7 is pretty normal. Any idea what caused the rod to let go? Are you running full E85 with PI?
04-26-2018, 04:59 PM
An other engine killed by PI.
04-26-2018, 06:33 PM
why death by pi?
04-26-2018, 06:36 PM
Post shift, let off, PI kept flowing.
Car: 12' 135i
04-26-2018, 07:38 PM
They are actually 2.3” and equivalent to a 3.2” single  on the 3 series I was referring to the 1 series though they neck down to a single 2.5” pipe!
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Car: 335i x-drive n55 2011
04-26-2018, 08:31 PM
is it what actually hapenned ? how is this possible
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
04-27-2018, 04:25 AM
4600rpm +31psi brake rod because you shifted manually at 5900rpm as when you have oem turbo
amazing that you could obtain +24.5psi from PS2.
+21psi PS2 is 100wgdc and W.R of fastest is running 23~24psi.
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
