uncleivenm135i's Avatar
uncleivenm135i uncleivenm135i is offline
Car: M135i
Default Jb4 f80 M3 cp wonít run - 04-21-2018, 12:44 PM
Hope you can help. Bought a jb4 off the forum (m3cutters in uk) and set about installing it on my comp pack f80 M3 today. Took around 2 hours and I installed all sensors (waste gates too)
Went to star the car and it misfired like mad and died.
I removed the obd connector and it re started, it ran for about 10 minutes.
Re connected obd and re started it and it wouldnít run, so disconnected it again and now it wonít even run with that not connected.
Iíve checked the sensors over and over and it wonít run. Put it back to stock and it fired up but now with an engine light?
Any thoughts ?
Car is RHD uk based
2016 M135i - JB4, standard
Default 04-21-2018, 01:34 PM
Not much to go on there, if you have install photos we can check it. Otherwise would need to see a JB4 log to check firmware, etc. Maybe somehow faulty before you purchased it...
Car: M135i
Default 04-21-2018, 09:56 PM
I’ll get some photos uploaded shortly
I don’t have BT or a cable to log though ? Are they supposed to be included
Car: M135i
Default 04-21-2018, 11:50 PM
https://www.flickr.com/photos/153979.../shares/4W1XDx
Car: M135i
Car: M135i
Default 04-21-2018, 11:53 PM
Just tried a few different ways this morning. I removed the waste gate controllers and linked them out and tried it with just maf sensors for stage 1 and got the same splutters and it died shortly after. I returned the car to standard removed all jb4, car runs fine so can’t be a faulty sensor any ideas
narstune's Avatar
narstune narstune is offline
Car: '11 E90 335i
Default 04-22-2018, 12:21 AM
Ensure that the molex-type connector is plugged in correctly. The pins should be aligned 1:1.
https://www.flickr.com/photos/153979...shares-4W1XDx/
2017 M3 ZCP
Car: M135i
Default 04-22-2018, 12:49 AM
Will go check now on the molex, cheers
Car: M135i
Default 04-22-2018, 02:13 AM
Looked ok, the clip locates it on pin 1-1
I do notice that one side of the molex has three pins terminated and the other only has one pin terminated
Default 04-22-2018, 11:13 AM
Please upload install pics and a screenshot of user adjustment settings to this site for review.
Car: M135i
Default 04-22-2018, 11:37 AM
I’ve upladed install pics
How do I upload user adjustment one?
Do I need a cable to connect to jb4?
Default 04-23-2018, 11:15 AM
You will need a cable to connect to the JB4.
I don't see any pics in this thread.
Car: M135i
Default 04-23-2018, 12:40 PM
Ok, will get a cable ASAP!
Pics
Default 04-23-2018, 08:58 PM
We don't click on 3rd party links...please upload them to N54tech.
Car: M135i
Default 04-30-2018, 10:53 AM
Update on this
I’m still having issues and I have no lead to connect the jb4 with (trying to find the one I need)
I’m only installing two sensors for stage 1
The rainbow and the brown wire ones
The car will run fine on the brown wire sensor with the stock rainbow sensor
When I connect the rainbow sensor it runs rough then dies (even when I remove the brown sensor and return to stock)
The molex connection is fine
I’ve got the menu 1 set to 4 via the stalk controls to auto clear codes
Any ideas?
Car: M135i
Default 04-30-2018, 10:54 AM
I’ve cleaned the connections on the rainbow sensor and all pins are straight
Default 04-30-2018, 11:10 AM
Photo of board? Maybe someone attached rainbow to the wrong sensor and fried it.
Car: M135i
Default 04-30-2018, 11:29 AM
What would fry the board or sensor?
I’ll post a pic of board now
Car: M135i
Default 04-30-2018, 11:35 AM
https://www.flickr.com/photos/153979383@N08/
Car: M135i
Default 05-01-2018, 12:55 AM
Did you guys manage to check out the pics
Default 05-01-2018, 09:05 AM
You'll need to upload them to this site...as previously stated, we don't use 3rd party links.
Default 05-01-2018, 09:09 AM
Iíll post a pic of board now
Sometimes people plug it in to the MAF sensor position and fry it as that's a 12v sensor. If you want to send it in we can always check it out here, address is on our website.
Car: M135i
Default 05-01-2018, 11:54 AM
I can’t upload pics direct unfortunately
Terry, do you know which chip would fry? There is a pcb repair shop on my industrial estate who could repair it if I knew which part would have fried if plugged into the 12v maf?
