mega mega is offline
Default HPDE proofing e90 335i - 03-23-2018, 06:01 AM
I've got a dedicated track car but I would like to use the 335i as a backup so I'm going to lightly prep so it wont limp on me.
It's a 2007 335i and has a JB4 & snow meth kit
I'm thinking this is what I need to do.
map1 with maxcool is going to backend flash any benefit for this? I have MHD already setup if needed
another oil cooler
HPDE pads that can handle advanced run group speeds.
anything else needed? I might get some camber plates too so I do not destroy the tires too quick, will be on street tires, probably > 200 tw too as it is a daily driver
Cloud9Blue Cloud9Blue is offline
Car: 09 E92 335i
Default 03-23-2018, 07:16 AM
- get rid of the meth kit, they aren't reliable enough for track use. you really dont want to hydrolock the engine because of jammed solenoid or something.
- does your car have an oil cooler? if it does, you will be ok for some light track use at 6/10 pace.
- don't expect to keep up with the advance group's pace with a mostly stock car though. not even full race pads like PFC01 or Cobalt Friction will last very long with the stock brake calipers and rotors.
- M3 suspension bits and some good shocks and springs are a must for this car if you care about handling
09 BMW E92 335i: EFR 7670 / Motiv / AP Racing / Wavetrac / TC Kline [Full Modlist]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
Default 03-23-2018, 09:27 AM
I would have a hard time doing 6/10ths
what M3 suspension parts do these cars need, control arms? I run meth in the mini at the track, only way to keep those supercharger temps down
vid from last trackday, that mustang in front of me has 425 hp, i got 200 lol
Default 03-23-2018, 09:30 AM
https://www.youtube.com/watch?v=naCAicVxEek">https://www.youtube.com/watch?v=naCAicVxEek" type="application/x-shockwave-flash" width="800" height="600">
Car: 09 E92 335i
Default 03-23-2018, 01:57 PM
your e90 is gonna feel like a pig comparing to the mini, at least in stock form.
the front m3 control arms helps a ton with the steering feel. looks like you are pretty comfortable with the mini already, so you will definitely need some camber plates and some good spring/shock/coilover setup as well. stiff or solid rear subframe bushings are definitely something that you will find helpful as well.
there just too much to explain in one post here. i would recommend doing some digging at the e90post suspension and track subforums. lots of good info there.
NacRacing335 NacRacing335 is offline
Car: 335
Default 03-24-2018, 09:23 PM
Yeah you will have to drive it easy. I was never able to track my car hard, the n54 wont handle the temps. 1st lap , 2nd lap, limp mode...
2008 E92 - JB4 G5 ISO , E85 Flash ,FBO , Stg 2 LPFP KW v2 Coilovers, M3 Suspension Arms And Bushings , Hotchkis Sway Bars, 19" CSL wheels 255/275
seroga1986's Avatar
Default 03-24-2018, 09:52 PM
Big oil cooler, trans cooler, maxcool, and 7.5" RACE intercooler. Ran map7 with e85 BEF on e55 mix. No issues no limps. Ran very hard for 25-30min non stop no issues. Mods in signature.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
