socaln54's Avatar
socaln54 socaln54 is offline
Car: 535i
Default Ideas for a DIY Custom Intake? - 02-11-2018, 09:36 PM
after reading many threads about the benefits and disadvantages of Stock Airbox vs DCI vs MR. 5 Intake vs Dinan Intake etc, I decided to trash all that and try to create a new concept, I have a 535i so the concept might be completely different for other models, I want to run aluminum intake piping with a y pipe all the way to the front of the radiator right where the BMW Bumper Cowl Hood inserts are, let me know what you think?
Car: 2008 E93
Default 02-11-2018, 11:05 PM
I wouldnt. Thats a tight turn for one. Another is the 2 into 1.
Car: 08 535i
Default 02-11-2018, 11:10 PM
CXRacing made one similar to this concept. Check it out here. this is what I was going to do, until I relocated my inlets....
https://www.cxracing.com/products-by...AI-BMW-N54-SET
socaln54's Avatar
Car: 535i
Default 02-11-2018, 11:17 PM
Its a concept, the merge can be anywhere
do you have a 335i or 535i?
Car: 08 535i
Default 02-11-2018, 11:21 PM
I have an 08 535i!
socaln54's Avatar
Car: 535i
Default 02-11-2018, 11:27 PM
I have an 08 535i!
do you have a picture of your setup? did you make it yourself or?
Car: 08 535i
Default 02-11-2018, 11:39 PM
I took a lot from Evan. But yes I did my own work. you can follow everything here.
http://www.n54tech.com/forums/showthread.php?t=46427
Here is where I am currently at...... awaiting my 6mt and solid sways!!! This is the rb EVO kit.
Car: 2008 E93
Default 02-11-2018, 11:47 PM
Great, but you asked about thoughts on the pic you posted. Are there any data sheets on that cxracing one posted ? I wouldnt feel comfortable with one 3" to two 2.5" regardless, unless there is data that proves it doesnt choke it.
socaln54's Avatar
Car: 535i
Default 02-11-2018, 11:53 PM
I see what you mean make sense
socaln54's Avatar
Car: 535i
looks clean, where did you get the pipe or silicone?
Car: 2008 E93
Default 02-11-2018, 11:56 PM
I could be wrong........Me personally, I wouldnt do a 3" to feed two factory 2.5"
Car: 2008 E93
Default 02-12-2018, 12:07 AM
I believe a 3.5" pipe flows similar (a hair less) to 2) 2.5". So at a minimum I would do a 3.5" y to 2) 2.5" if you have room for it.
Then again, 2 dci and you lose nothing as far as flow is concerned.
socaln54's Avatar
Car: 535i
Default 02-12-2018, 12:16 AM
or even go with a 4", I like Ryan's setup for the inlets, seems the "better" way to go
Car: 2008 E93
Default 02-12-2018, 12:19 AM
Relocated inlets are PROVEN to work as far as flow is concerned.
Car: 08 535i
Default 02-12-2018, 12:49 AM
the kit I have installed now is a RB EVO intlet kit. You have to email rob at rbturbo.com for pricing and availability as they are not available for purchase directly from his site.
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 02-12-2018, 12:11 PM
For whatever it is worth, I am selling an RB EVO Inlet system with less than 5k miles on it. PM me for details. Sorry for hijacking the thread.
Sam
Car: 08 535i
Default 02-15-2018, 09:30 AM
Sam
How much you want for this? I may know someone interested!!!
This is the only hotside intake kit I think "I THINK" the 535i will be ok to use without relocating the A/C suction line. Maybe I will make a seperate thread on why I think they will work.
