BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default Changing Tranny Fluid - 02-03-2018, 03:36 PM
Question/ I have a 135I and it is time to change my transmission fluid.
Car -86,000 miles. What is the best fluid I can put.
1-Liqui Moly.
2-Red-Line
or stay with factory fluid.
I heard some people putting red line and transmission slipping.
Liqui Moly is used in the GTR cars , is very sticky to the clutches,
but I have not seen any reviews yet on the N54 tranny .Any suggestions.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 02-03-2018, 05:58 PM
I have tried redline once when doing valvebody upgrade.
I can't tell you if it was better then OEM or not as my AT started slipping at 620 wheel torque.
Default 02-03-2018, 06:00 PM
I use Redline MTL. Not knowing what transmission you have complicates suggestions.
N54 | Build Thread
BMW135xi's Avatar
Car: BMW 135I
Default 02-03-2018, 06:07 PM
i have At(Steprtonic) tranny , not manual or DCT
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-03-2018, 07:48 PM
I used Pentosin. Has worked great so far, 20k with no issues.
seroga1986's Avatar
Default 02-08-2018, 09:33 AM
Use OEM only. I have used redline and trans started slipping. There should be some threads on here about this.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
BMW135xi's Avatar
Car: BMW 135I
Default 02-08-2018, 01:37 PM
Ok thanks, I will keep my OEM .
