(#376)
BoostAddict BoostAddict is offline
Car: e46 323i/ 04.5 Turbo 350Z
Default 03-31-2016, 07:29 PM
Large diff braces are back in stock and shipping!
www.BoostAddictions.com
Custom Engine Calibrations and Performance Parts
996 Turbo
Default 04-04-2016, 08:39 PM
Bump
996 Turbo
seroga1986's Avatar
Default 04-10-2016, 04:22 PM
These fit 135 with AT? Will it help on the AT?
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Default 04-11-2016, 10:45 AM
Yes, they fit 135's. It will definitely help clean up the rear end slop. As far as wheel hop, idk how much of an issue that is with the 6at cars. If you had some, it should go away.
996 Turbo
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 04-11-2016, 11:32 AM
It does help with wheel hop in 6AT.
Stock AT might not have much problem wheel hop, but with mods it sure does.
This diff lock down fits and works great!
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Default 04-12-2016, 06:55 PM
I'm glad you're still happy with your purchase!
996 Turbo
gunda gunda is offline
Car: BMW 335i E92
Default 05-15-2016, 07:52 AM
Just sent you an email, I totally missed out on the pre-orders, but really want to get a lockdown still. Hopefully you can do another round of discounted pre-orders.
Default 05-15-2016, 05:48 PM
Just emailed you back. The Sale price will remain until June 1st. Let me know if you have any questions.
996 Turbo
Default Sale Ends at Midnight! - 06-01-2016, 07:53 AM
Last chance to get a diff brace on sale for 150 with free shipping (free shipping for U.S. Customers only). Sale Ends at Midnight, so Don't miss out!
Also, be sure to like and follow us on Facebook and Instagram!
facebook.com/boostaddictionsinc
@BoostAddictions
996 Turbo
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 06-11-2016, 04:10 PM
Originally Posted by 4doorbmwpower
anyone got any ideas for a lockdown that would fit on the VAC diff cover?!??!? i would buy it
I think I can work something out for your VAC diff cover.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 06-11-2016, 04:27 PM
I just made a new bracket that used the top 3 VAC diff holes and same pivot hole location as original bracket. So bottom bolt hole in original bracket is not used but next bolt hole above original bracket hole is. I have vwetish defiv brace
vwetish's Avatar
Default 06-11-2016, 08:56 PM
Very good solution. Cutting off the bottom one and going with just two would also suffice. The simple brackets use two bolts anyways...
Default 06-12-2016, 04:34 PM
Probably similar to what Defiv did for the M3 kits if I'm imagining that correctly lol
I love when you bump my threads for me!
996 Turbo
vwetish's Avatar
Default 06-12-2016, 04:49 PM
No, m3 has diferent subframe, this will not mount. Another bump for great seller!
pcoak1@gmail.com pcoak1@gmail.com is offline
Car: bmw 535i sport
Default 02-06-2018, 02:38 PM
are these still available?
vwetish's Avatar
Default 02-06-2018, 02:43 PM
What model BMW are you inquiring for? I see 535i in your signature. Nothing available for 535i
Default 02-07-2018, 07:29 AM
We have small braces in stock.
We haven't had much demand to do another run of large braces. If enough people were interested we could. Maybe a group buy?
996 Turbo
limitdown's Avatar
limitdown limitdown is offline
Car: 2007 335i E93
Default 02-08-2018, 06:43 AM
I've been running this brace for about 2yrs and it's held up perfectly against my mFactory helical LSD.
Default 02-08-2018, 08:14 AM
I'm glad to hear that! Thank you for your business/support.
996 Turbo
erichale's Avatar
Car: 335i coupe
Default 02-08-2018, 02:23 PM
Modified mine to fit VAC diff cover
vwetish's Avatar
Default 02-08-2018, 02:28 PM
Attachment 71392
Had I know I was going to send you a plate pre cut. They also work with e60 finned plate and m3 diff on non M subframe.
erichale's Avatar
Car: 335i coupe
Default 02-08-2018, 02:32 PM
I bought this from you years ago, way before that plate was available but thanks. This brace works great!
