Ga.silva10 Ga.silva10 is offline
Car: F22 M235i
Exclamation trims stucked in 25 - 10-11-2017, 09:18 AM
hello i wonder if someone can help me with my car. looking in some logs i saw that the trims parameter get stuck in 25 several times in the run. it is this normal ? if not how can i fix the problem , i want to add a little bit more boost but someone said to me that with the trims stucked the car cant adjust the AFR.
thank you very much
regards
Default 10-11-2017, 09:20 AM
Trims seem OK to me. It moves to 25 during open loop behavior (like shifts) and moves back after.
