Ga.silva10 Ga.silva10 is offline
Car: F22 M235i
Exclamation HELP LOW BOOST VALUES MAP 6 - 10-09-2017, 11:26 AM
hello terry,
i was wondering if you can help me with my car. My car is a bmw m235i (electronic wastegate) with charge pipe ******* ******** water meth inyection and the jb4. The car is running pretty good but i think it could be faster with a little map adjustment. this is my log 4th gear run map 6 water meth and (nos octane booster) the car has the oem turbo, i think it can charge more than 15 psi
it would be great if you can advise me which values i should change to make car be faster and in a safe run
user adjustment
thank you very much
regards from colombia
Default 10-09-2017, 02:34 PM
Map 6 log looks fine but its a pretty short log...if you increase boost, keep an eye on your fueling and timing.
Car: F22 M235i
Default 10-09-2017, 02:57 PM
could you help me with that ? which values should i increase to get a little bit more of boost ?
boost aditive 40
signal scaling 60
thank you
