(#3351)
ActorDanielOrtiz ActorDanielOrtiz is offline
Car: bmw 2018 440i Grand Coupe
Default 10-16-2017, 11:52 AM
Hello I need some help pretty please.
Bought a 2018 BMW 440i Grand Coupe, with jb4 installed.
the menu items for tach meter has me confused...
when i click over to tach from maps, the first thing shows is just beneath 20mph. which would be
the sound(20mph) right?
next would be boost gauge? (40mph)
then after would be angel eyes (60mph)
when i mess with these settings and change the boost gauge off. still comes on.
So i believe my map menu is either different from the video or maybe I am not doing it right.
if you want to lend a hand, I would really appreciate your help.
danielortiz20@gmail.com
thank you!
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 10-16-2017, 11:55 AM
'0 map menu, map shown on tach. Note map guide above.
'1 Not used for this model
'2 Boost gauge on fuel, boost is shown in the fuel gauge under heavy throttle with empty being 0psi boost and full being whatever you've assigned to your boost failsafe PSI on the user adjustment page. Default is 18psi. (OFF tach = 0, ON tach = 1000)
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
'4 Delete Fault Codes.
'5 1st gear boost limit setting. 0-7000rpm = 0-20psi.
'6 2nd gear boost limiter
'7 3rd gear boost limiter
Default 10-16-2017, 12:01 PM
I have the same menu but unfortunately it does not let me turn it off unless I am not correctly going through the menu.
(20mph on tach is this CORRECT?)'1 Not used for this model
(40mph on tach is this CORRECT?)'2 Boost gauge on fuel, boost is shown in the fuel gauge under heavy throttle with empty being 0psi boost and full being whatever you've assigned to your boost failsafe PSI on the user adjustment page. Default is 18psi. (OFF tach = 0, ON tach = 1000)
(60mph correct?)'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
and so on and so fourth you get my drift.
Thank you for replying
tauzins tauzins is offline
Car: 2014 335i m-sport
Default 10-16-2017, 06:26 PM
Originally Posted by Frikiton
the CEL came on as soon as you updated to EWG12 but more is the update for JB4 Mobile app.
I had EWG11 for months and didnt update my jb4 mobile app until recently to confirm this. But I have Bootmod3 flash so I dont worry about CEL i was just testing some stuff on stock map
if you dont mind me asking, how do you like the combined bootmod3 flash with the jb4 combined? worth it?
Default 10-16-2017, 06:43 PM
Starts at menu0 and you count the clicks to determine what menu you are on. The boost gauge would be 2 clicks up and if its enabled tach will jump to 1000rpm on that menu.
hi rpm's Avatar
hi rpm hi rpm is offline
Car: 2013 335i xDrive Coupe
Default Board Reset - 10-18-2017, 01:31 PM
I inadvertently started a "board reset" with the unlabeled button in the software, with the car running. I didn't know if it would be worse to unplug it or leave it, so I left it; at the end the blinkers flashed and the car shut off.
Nothing seems wrong, but did it do anything?
EDIT: Sorry, wrong thread, it's an E series!
Default 10-18-2017, 01:58 PM
I don't know what that is, but if the car is running fine, sounds fine to me.
hi rpm's Avatar
Default 10-18-2017, 02:09 PM
Under the Settings tab, lower right, little gray button with no text. Click on it and it says
"Board Reset
To enter boot mode, unplug JB4 box from harness, press OK, connect grey USB cable to JB4 box, connect JB4 box to vehicle harness, then turn on the vehicle ignition. If successful, the JB4 will request firmware to be uploaded."
I don't think I hit "OK", but X to close, and it started doing its thing.
Default 10-18-2017, 04:29 PM
Got it, it used to be called "disaster recovery". That only takes effect if you disconnect the board and plug it back in while that process is running. So you're good to go.
hi rpm's Avatar
Default 10-18-2017, 04:49 PM
b4zzy b4zzy is offline
Car: m135i
Default 10-21-2017, 03:42 AM
HI
i am looking for some help with my f21 m135i with JB4 bms intake ***** and mpe.
i recently have been getting some errors on the jb4 about valvetronic being disabled .
can anyone tell me what valvetronic is and what it does?
thanks
Fred123 Fred123 is offline
Car: 2014 435i x drive
Default max boost 14.8 psi? - 10-26-2017, 08:02 PM
Hi guys new to everything here. I drive a 2014 435i with a jb4 (map) with a bms intake and a ER ********. Recently got the jb4 connect kit and did a log. Max boost was 14.8 psi. does that sound right? also if you guys can take a look at the other stuff.I just want my car to be running well
2017-10-26 22_38_28.csv.2017-10-26 22_38_28.csv
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 10-30-2017, 03:24 AM
can you register battery with n55 jb4?
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Default 11-07-2017, 05:03 PM
Not an F series, yet.
erwan35's Avatar
Car: bmw 335i e92
Default 11-10-2017, 07:02 PM
For rhd n55 f10. Where do i put the cable thru for me to access the firewall? I tried to find a whole or something but i couldnt find it. Its difficult when i had to open up the hood everytime i want to connect with the jb4.
Default 11-10-2017, 11:15 PM
Get the blue tooth, or run it along with the OBDII cable.
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 11-12-2017, 03:51 PM
All, quick question, is there and auto clear for fault codes related to ******* down pipe? I have JB4 on my N54 and it auto clears. On the F30 N55 I keep getting a “******* down pipe detected” code. I can clear the code using the steering wheel controls or when connected to my laptop. It would be great if it did this and I just don’t know how to activate. Thanks!
Sam
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 11-12-2017, 04:49 PM
The auto clear has been removed from all JB4s.
Mike Levy
2021 Tanzanite Blue II M550i xDrive
2018 Silver Equinox LT 2.0T
Default 11-12-2017, 05:16 PM
Sam
If outside the USA there is a passive delete option on the WMI page. Inside the USA, that option is blocked.
Boostplz Boostplz is offline
Car: 335i Xdrive M sport 2013
Default 11-14-2017, 06:02 AM
Originally Posted by b4zzy
HI
thanks
hi I have the same problem, my valvetronic is disabled, I haven't updated jb4 .. could this be the problem, please some one help us!?
Jm276607@gmail.com Jm276607@gmail.com is offline
Car: 2013 bmw 335ix
Default 11-18-2017, 10:05 PM
Sorry if this is already posted somewhere. Having trouble using the search tool bc it keeps omitting popular words like 'jb4' and 'turbo'.
If you install fbo and a turbo kit like speedtech, which map should you use? Should you get a custom tune? Is there a way to have multiple maps for different max hp outputs? Like one at about 400 and one at about 500?
Car: 2013 bmw 335ix
Default 11-18-2017, 10:06 PM
Is there a way to have multiple custom maps to align with with different boost levela of a speedtech kit?
Jantsa Jantsa is offline
Car: BMW F11 535i
Default 11-19-2017, 06:29 AM
Was driving today and noticed that the car was "jerking" when i accelerated. Then i did read the error codes with my jb4 and got "121002 MAP sensor,short to ground" anyone else have had the same issue? Or is my MAP sensor just going nuts and need to buy a new one. Thnx!
N55Frank N55Frank is offline
Car: 2013 335ix
Default 11-20-2017, 02:24 PM
Hello everyone,
Default 11-20-2017, 03:53 PM
Originally Posted by N55Frank
Hello everyone,
If you need technical support you can email or make a thread in the support area. We'll want to see installation photos, maybe a JB4 log, and any other information you can provide.
