Keeping IATs low with inlets with heat reflecting blanket and air scoop -
03-24-2016, 07:04 PM
I got this idea from a 335 owner that tracks his car and he said it helped alot. This is my own custom 2.5" inlets with a heat reflecting blanket and a cheap air duct/scoop (temp for now). Well after adding this the IATs are about 3 to 8° hotter than ambient on the highway at 60mph. After back to back pulls the temps fall back to the 3 to 8° range real quick. On track last year i had no problems keeping IATs about 15-25° cooler than when i had DCIs with very simular ambient temps. Excuse my temporary cheap air duct/scoop but it sure does help (combined with afe grill scoops) as there is a bunch of bugs/dust/tiny rocks in the filters after a few hundred miles. I am going to make a nicer air duct when im done with my oil cooler project here soon. Hope this help someone and or gives ideas to people.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Car: 08 E92 335i N54
03-24-2016, 08:04 PM
Apparently the 335D air scoop will route air to that side and should just bolt in!
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
Car: 335i, 6sp Mt, Fbo with 2.3 gal meth with Do 3 &7 nozzles 100% bmw washer concentrate, it's free:)
03-24-2016, 08:08 PM
Super cool dude! I have been thinking in a similar manner! Check out the gold foil heat reflector wrap that is what I wanna use, my under hood is gonna look like a space ship
If it isn't too much trouble do you mind explaining what you used to make inlets and where you sourced k
It? For the price it just seems like a good idea to buy the damn kit...
03-24-2016, 08:09 PM
Or it could be an older 330d. I think the guys were using a hack saw for the perfect angle. Hope this helps  all youd need in addition are some ram air scoops like the AFE ones
03-24-2016, 08:20 PM
I made my kit right after MMP made their kit so non other kits were out except that and trueform technology. This is a heat reflective blanket not heat wrap or exhaust manifold wrap. They say it works just as well as gold tape but looks better. Remember shiny side down to reflect the heat.
Yeah just buy one of the kits now - it will probably be cheaper but if you are interested i can send you the blueprint of my setup.
2008 135i Sport 6at
03-24-2016, 08:39 PM
Ok thanks and I like the raw look over pretty any day if it work! I'm sure I will become a junior thermodynamicis once I decide to dive into heat management lol
Car: 2008 BSM 135i
03-25-2016, 07:39 AM
Saw you post this on in one of the Facebook BMW groups.
Love the idea. Can you send me a link to the heat blanket stuff?
Also, for the guy who recommended the 335d air duct... it doesn't fit the 135i. I already tried. I'm sure with some hacking and modification, it would work. But the two scoops don't line up.
Car: 1M
03-25-2016, 10:35 AM
You don't want to scoop air in, you want to vent hot air out.
Neil
Car: 08 335xi
03-25-2016, 11:29 AM
Spend more time in making your FMIC more efficient. No point cooling air that's going to get compressed and heated
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: n54 335i
03-25-2016, 11:35 AM
Can you please show how you secured the heat reflective blanket and the routing? Im planning to do this with the 335d air intake
Car: BMW 135i N54
03-25-2016, 01:45 PM
+1
Car: 2009 335i e92
03-25-2016, 01:52 PM
? what about the heat you entrap underneath the blanket? wouldn't that be something to think about
2009 335i e92 n54 | FBO | JB4 | e85 flash |
Car: e82
03-25-2016, 05:26 PM
Just wrap your DP's and wrap your outlets with that gold tape stuff. That would be more efficient and would be beneficial.
Car: 08 335xi
03-25-2016, 07:49 PM
I think the thought process with this is if the air sucked in is cooler (with this blanket stuff vs without) from the start... it will either not get as hot or not get as hot as quick (as without it) when the air is "heated and compressed". goal being the intercooler would decrease temps at the same if not a faster rate(again compared to a slightly higher temp w/o these items).
I'm not sure if that's accurate but in simple terms that's how i understood it and make sense to me. I believe this is one of those things where you are looking/hoping to get any little bit of a benefit that you can. Can't hurt right?
Car: n54 335i
03-25-2016, 09:18 PM
That's right. The cooling capacity of the FMIC is constant even after you upgrade it. But IAT is variable and cooler it is , better it is for the engine.
Car: BMW 335I N54
03-27-2016, 04:28 AM
would this fit the N54 ?
08-28-2016, 09:30 AM
Did it fit?
Car: 2007 e92 335i
08-28-2016, 11:20 AM
Yes but you have to shave it down a bit because it's slightly too wide. Easily done and self explanatory when you go to install it. I just used a metal file.
08-28-2016, 01:47 PM
I snagged one off a customers car and test fitted it on mine and it worked fine with no mods..
I only used the top part though
My intake air temps at cruising speed where always 12 to 13 over ambient.. When I tested with just the top part of the diesel duct they were 6 to 7 Deg above ambient..
I never logged any pulls back to back but I can assume they would be bettet
2007 BMW 335I
jb4 g5 w/n20 tmap & e85 bef
bms 2.3 meth w/DO 5 & 7 nozzles
Vrsf dp's
Ebay chargepipe w/ 2 meth bugs and tial 50
6x6x23 intercooler
mmp inlets and outlets
E50 mix w/fuel it stg 1 lpp
Bosch n55 plugs @.22
Rear diff lock down
550i clutch w/cdv and e46 M3 Trans mounts
B&M short shifter w/bmw perf weighted knob
Car: 2010 535xi
08-28-2016, 02:25 PM
I'd be pissed if i took my car into a shop and I found out you were pulling parts off my car to test on your car (assuming you didn't ask permission).
Just sayin'.....
6MT, JB4, DCI, BMS Pump BEF
08-28-2016, 07:14 PM
Just sayin'.....
The car was a total loss flood Car.. I think it was the least of their worries bud..
2007 BMW 335I
Vrsf dp's
6x6x23 intercooler
Rear diff lock down
Car: BMW 335I N54
09-19-2017, 04:38 AM
U got a link to the blanket?
09-19-2017, 08:10 AM
It was something like this but bigger in size. I dont remember where i ordered mine but i remember it was pricy.
https://m.summitracing.com/parts/tay-2545
2008 135i Sport 6at
Car: BMW 335I / VW 2.0T
10-10-2017, 07:23 AM
This part isn't available in US. 325/330d never made it here  What car did you take it off?
