noahssracer noahssracer is offline
Car: 535i
Default engine swap question - 09-07-2017, 01:42 PM
I am swapping a complete engine into my 08 535i, will there need to be any programming done after the install?
sorry for dumb question..lol
Sheldon
Car: All of 'em
Default 09-07-2017, 09:25 PM
I mean, this is rather unclear, but provided you have a direct replacement engine you won't need to do any 'programming' but resetting adaptations is recommended.
limitdown's Avatar
limitdown limitdown is offline
Car: 2007 335i E93
Default 09-08-2017, 06:18 AM
Of course there's a lot of time and labor involved, but an engine swap is plug and play.
I'm not sure about 535's, but some of the older 335's had 6-bolt pattern flywheels. Most are 8-bolt pattern.
eaton18spd eaton18spd is offline
Car: 2008 535xi
Default 09-08-2017, 09:37 AM
Injector coding and adaption reset should be about all you need to do.
Car: All of 'em
Default 09-08-2017, 09:41 AM
As long as they are installed in the same location they were removed from, they will not need coding.
limitdown's Avatar
Car: 2007 335i E93
Default 09-08-2017, 09:46 AM
My shop just used masking tape and wrote which cylinder each injector came out of.
Car: 2008 535xi
Default 09-08-2017, 09:53 AM
OP did not indicate how he was handling the injectors and/or DME. So, to clarify my statement, If he is to use the injectors in the new engine and is using the original DME, then yes, they do need to be coded. If he is using his original injectors in the new engine and not changing the DME and puts them in the same locations in the new engine, then no coding is required.
Car: All of 'em
That'll work. Considering the possible headache associated with recoding the injectors if you accidentally mix them up, it's worth spending a few minutes, take a picture, write it down, and mark it. Why not?
Car: 535i
Default 09-08-2017, 03:16 PM
I will use original injectors and DME. thanks everyone!
