Limpmode's Avatar
Limpmode Limpmode is offline
Car: 2007 E90 335i
Default Looking to max out WMI with 100 octane race fuel - 09-02-2017, 10:07 PM
I'm planning to run 100 Octane race fuel with the WMI kit next time at the track. Is 75 add the most I can run? I want to max out stock turbos. I'm running the MHD race BEF. I'm looking for max boost.
07 335i; JB4, Anti Lag, MHD BEF, BMS DCI, Phoenix CP, Tial BOV, MAP OC, BMS OCC, 1320 Down *****, MMP Inlets, RB Ext PCV, Mishimoto OCC, BMS Meth, N20 TMAP, VTT stock+billet comp wheels, Blk124 Wheels (5series take offs staggered), 275/35/18
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-03-2017, 05:06 AM
I believe with stock TMAP anyways you are limited to 21 psi. If you have the N20 sensor the scale of the adder it totally different
Limpmode's Avatar
Car: 2007 E90 335i
Default 09-03-2017, 06:24 AM
Yes, I should have mentioned I have the N20 TMAP (3.5bar).
Rushan's Avatar
Car: 335i E92 2009
Default 09-03-2017, 06:54 AM
With the N20 I believe the 75 adder will even be beyond your stocker limits 75 adder without N20 will target 19.5 psi with N20 enabled I guess that would be 23-25 psi and stockers more than maxed out.
Seen a post previuosly that Terry mentioned adder can go to 85
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-05-2017, 02:09 PM
Yes, with 3.5 bar and 75 adder, boost peaks at 25 psi. Would be very surprised stockers could put down that much boost.
Limpmode's Avatar
Car: 2007 E90 335i
Default 09-05-2017, 06:18 PM
Thanks for the info guys^!
We'll see what these stockers can throw down.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 09-06-2017, 06:50 AM
Oil and bearings
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
seroga1986's Avatar
Default 09-06-2017, 09:17 AM
Really fellas? We know that stockers can go to 25-26 psi. I have been there for 1.5 yrs. At those boost levels its probably very near 500whp and 550+wtq.
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Limpmode's Avatar
Car: 2007 E90 335i
Default 09-06-2017, 01:56 PM
The real test will be to see if the stock ignition and plugs can hold up! I'm very near the point of needing a switch to NGK's and a smaller gap. It might be time for a coil upgrade as well.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 09-06-2017, 02:05 PM
Boost =/= horsepower.
if you're set up doesn't flow well, stockers can hit 25 psi.
if it does, you can't because it's flowing more.
Ignition should not be an issue if your coils/plugs and tune are in good shape.
Originally Posted by AWSAWS
Oil and bearings
lol - exactly
AWSAWS's Avatar
Default 09-07-2017, 03:44 AM
There must be so much back pressure and hot air flowing at those boost levels on the little stockers.
I was tempted to try it myself but I stuck with 23 psi. Didn't want bits of Turbo breaking off and causing collateral damage.
