Originally Posted by NorCalN55
Probably not. How long did you let it crank before you checked the gauge? If you let it crank 10 times and you still don't see improvement, then do a leak down test. You can also pour an 2-3 ounces of oil in the cylinder and retest...wet compression test. Doing a wet compression test before the leak down test will impact the leak down test results because the added oil can cover up potential locations for an air leak.
I let it crank for about 8-10 seconds. I watched the gauge and after it didn't move for about 3 seconds I stopped.
I used my air compressor to test the gauge and the gauge might be reading about 10 psi to low. If all cylinders are pretty much identical, but just all low, what could be the issue?
