Car: F20 M135i
N55 1/4 Mile - ET 11.2 - F20 M135i -
05-02-2017, 07:19 AM
Hi guys,
I just want to share my results from this weekend.
1/4 Mile in 11.240s and 129.9mph.
And I would like to say thank you very much to my tuner here in Brazil, Alex Trambaioli (Automotive Motorsport), to Terry from BMS, Dzenno and Halim from ProTuningfreaks, Steve from FuelIt, and Peter from Pure Turbos.
If not mistaken, this may be the new world record for N55 rwd.
Here are the YouTube video link:
https://www.youtube.com/watch?v=9iYU7tSQgpc
https://youtu.be/ZEiVCkpeng4
Elevation from sea level: 750 meters (2.460 feet)
Temperature: 70F
Car: 2015 BMW F20 M135i EWG
Mods: Pure Turbo 2, JB4, BM3 BEF, FuelIt PI and LPFP, FBO and Hoosier DOT Drag Radial
Result and car photos attached.
Jose Carlos Neto
F20 M135I N55 EWG 2015, Pure Turbos Stage 2, bootmod3 backend flash, JB4, FF wires EWG, E25 95AKI, Afe Power intake, Wagner Tuning dp, ER chargepipe, WagnerTuning FMIC, BMS WMI, DV +, Pure inlet, FuelIt PI and LPFP, BMW M Performance Limited Slip Differential, H&R springs, Stoptech slotted and dimpled front rotors, Turner stainless steel brake lines, carbon fiber hood, Liteblox battery, Apex Arc-8 wheels, Toyo R888.
Reason: Grammar error
Car: 2016 F25 X4 M40i (N55)
05-02-2017, 02:46 PM
Congrats!!!
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
05-02-2017, 04:53 PM
Awesome time!
2013 DCT Jet Black 135i
-JB4 Stage 2 ISO/w Flex Fuel Wires-Fuel it Stage 3 Bucketless LPFP-PDU Port Injection-Big Boost 6564 Bottom Mount Turbo Kit-Big Boost Chargepipe-Active Autowerke-BOV-Injen SP Intake with Blox Velocity Stack and Turbo Guard Filter-VRSF 7.5 in Stepped Race Intercooler--BMS OCC/OCV/CF-N20 TMAP-N20 Plugs-Motul 300v 5W-40-Archoil 9100-Motul Mocool-Custom 3.5 inch Straight Pipe Exhaust-Stoptech Rotors/Fluid-PFC Track Pads-VMR 710-Toyo R888r-M4 Flywheel- SSP R Clutches
05-02-2017, 08:18 PM
Congrats ! Keep it up
18 BMW XXXX Car in Process
Car: F20 M135i
05-03-2017, 05:50 AM
Big Congratz!
Car: 335i x-drive n55 2011
05-03-2017, 06:11 AM
give the man a beer ! very nice !
335i x-drive 2011 e90 n55
Car: F20 M135i
05-03-2017, 06:32 AM
Car: 2011 BMW E93 335i LCI
05-03-2017, 08:05 AM
Awesome! What power are you making?
Car: M135i
05-03-2017, 08:27 AM
Nice
2016 M135i - JB4, standard
05-03-2017, 10:10 AM
how many psi?
Car: F20 M135i
05-03-2017, 11:13 AM
510whp
Car: F20 M135i
05-03-2017, 11:14 AM
Originally Posted by 135idct
how many psi?
24psi
05-03-2017, 03:44 PM
Originally Posted by NetoM135I
24psi
did u limit the boost in 1st and 2nd gear?
05-24-2017, 07:08 PM
How much Ethanol E50 or 100% ?
Car: F20 M135i
05-24-2017, 07:11 PM
E40
Car: 2011 135i
05-24-2017, 07:55 PM
What are the spec of the Apex wheels?
Car: 12' 135i
05-24-2017, 10:03 PM
Great time, and AWESOME trap! Pure FTW, what's the car weigh in at?
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Car: F20 M135i
05-26-2017, 01:20 PM
ARC-8
18x8.5" ET45
18x9.5" ET58
APEX 3mm BMW Spacer Kit
Car: 2011 135i
05-31-2017, 10:05 PM
ARC-8
18x8.5" ET45
18x9.5" ET58
Nice, I’m getting a M140i and was hoping to use a set of wheels I have already that are
18x8.5 et35
18x9.5 et50
Sounds like it should work with slightly stretched tyres.
Great times by the way.
Car: 11 135i
05-31-2017, 11:23 PM
18x8.5 et35
18x9.5 et50
Welcome back maaaaate.
Car: M135i
06-03-2017, 09:31 PM
Great time! Definitely a 10 second run in there with an improved 60ft which I'm sure you will achieve.
The 1er's trap a good bit higher than the heavier 3/4 series cars. Is there any more room in your tune for more power or would you say this setup is maxed out?
M135i 8AT / JB4 + EWG Harness / N20 TMAP / VRSF 5" HD FMIC / Fuel-It TBI / Fuel-It STG2 LPFP / Pure High Flow Inlet / FTP Charge & Boost ***** / Richter ***** / Backbox delete / E50 Fuel / ngk 5992s / BBS CH-R's / KW V3 Coilovers / M4 LCA's / GP Front Splitter & Side Blades.
100-200kph: 7.8s
1/4 mile: 11.9s @ 120mph
