Originally Posted by TSRxi
i tried vargas but he is too swamped to do it now. I ended up doing it myself. If anyone in the bay wants advice or to borrow my Walnut blaster set up PM me. you need a 7.5 CFM at 90PSI compressor to run this deal correctly. Shop vac.. You can filter and use the walnut media I have or $25 for new box. It takes about 5+ hours depending on how bad your valves are.. Mine were as bad as I have seen. worth doing.. night and day since I did it. way more power, no more misfires, smoother idles better. I will be using Amsoil powerfoam at least every 3-5k miles and get a Oil CC. see how it goes.
Yeah VTT is pretty busy. I ended up going to P-tech 3 weeks ago and had them do a intake cleaning and had them install my bms occ since they were under the hood. Car feels good but that's expected when you've got new injectors, plugs, coils, oem turbos, and clean intake. Now time to get some DP's.
