08335ibmw 08335ibmw is offline
Default Log check jade water pump replaced and some injectors - 02-25-2017, 12:08 PM
As title says.. thanks!
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
Default 02-25-2017, 01:25 PM
Just had *
Default 02-26-2017, 07:21 PM
Bump
Default 03-01-2017, 09:07 AM
Open loop is too high and trims are maxing out. Map 2 looks to be too aggressive so I would recommend loading the BMS pump flash.
Default 03-01-2017, 11:15 AM
Ok what should I set F.O.L. to
Default 03-01-2017, 03:16 PM
Lowered to 80 any better?
Default 03-01-2017, 03:59 PM
Why would map 2 be to aggressive?
Default 03-03-2017, 04:58 PM
Steve what should my folks be set at?
Default 03-04-2017, 12:28 PM
Trims and FOL are maxed out....you need a flash.
You are pulling timing...that indicates the boost target is too aggressive.
Default 03-07-2017, 04:06 PM
Have not had a chance to bef. But will soon I put it to map 1 , any better?
Default 03-07-2017, 09:33 PM
Still pulling timing and trims are still pretty high.
