(#101)
a335i a335i is offline
Car: 2008 335i sedan
Default 12-15-2016, 09:06 PM
Installed it then the codes appeared after a while cleared codes then I shut the car off, then removed battery to install the BMS water -meth kit connected the battery then codes showed again and could not clear it, now my JB4 when trying to change maps the needle seems way of it jumps not like it used too the water -meth tried it it works fine.
Default 12-15-2016, 09:11 PM
If you need technical support email in or use the support forum.
Default 12-15-2016, 09:15 PM
Can I have your email please?��
Default 12-15-2016, 09:18 PM
Our email address is on our website. Email in the BMS order number for the sensor at the same time so we can identify you when you email in.
ah335i ah335i is offline
Car: 08 335i
Default 04-24-2017, 01:26 PM
Dear N54tech friends, i have installed to my car the 4 bar map sensor to my car, i did the latest jb4 firmaware update, N20 set to (2) but iget 2 codes randomly when turning off the car not while using it. and not always.
codes are :2ABC,3100,2ABD
car fill great as i told you this codes i dont get until turning off car and then on again not while running.
will this affect performance. how can i fix this im i missing an option on the Jb4
i running the Race flash backend.
