(#76)
Car: BMW 1M Coupe
Default 05-27-2016, 04:01 AM
Hi quick question, is the 4bar Tmap sensor adapter same as the n20 3.5 bar Tmap sensor?
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 05-27-2016, 01:22 PM
Has anyone noticed or had issues with your intake temperature holding at the exact same temperature or not changing unless it really rises?
Mine works fine for about 5 minutes then doesn't move for sometimes 15 minutes even if I stop at the lights for a bit and do some wots.
Doing 3rd wot won't even change the temperature sometimes.
Default 05-27-2016, 03:01 PM
Interesting, could be a faulty sensor. Have some logs of a longer run?
No the 3.5bar is continental and the 4bar is Bosch.
the imitator the imitator is offline
Car: e30
Default 05-28-2016, 12:21 PM
Originally Posted by chatz86
Won't WD40 destroy the O rings? Ive always used molykote silicone grease to lubricate the O rings. I thought WD40 would dry out and damage the O rings?
Yes, WD40 will dry out Orings and turn them into a slimy mess.
The best Lubricant you can use on Orings that are making a seal, is Molykote DOW55! If the orings see any motion like on Spool Valve style paintball markers you use DOW33 from Molykote. Dow55 is very thick, and causes orings to slightly swell, great products that has been around for years!
Default 05-28-2016, 12:22 PM
FWIW on orings like that I just use a little motor oil. Never had an issue with it.
brendan's Avatar
Brendan
Default 05-29-2016, 04:06 AM
I've got logs of all sorts.
It just works from start to normal iats, then it just stays at xxx f and is like its more delayed rather then Instant reading and maintains the same xxx f temps compared to stock which would change a few single units nearly continually.
For example give it a quick slight boost and its goes down about 3 f but with the 4 bar I have to do at least a 3/4 redline 3rd wot and it might move 3f then quickly go back to xxx f.
I don't have jb4 i just wanted to know if others are experiencing the same delay
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 06-14-2016, 05:41 PM
Swapped to 4 bar tmap , should I change anything in my flash ?
Do more with less !
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 06-14-2016, 05:48 PM
Flash should stay the same, the JB4 sends back stock TMAP values, so it won't be compatible if you try to adjust the TMAP in the flash. Just change the TMAP setting in the JB4.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
Car: BMW E90 335XI
Default 06-14-2016, 05:53 PM
Thank you so much for your prompt reply @Jayock
Do more with less !
Default 06-14-2016, 06:24 PM
No flash changes needed, except in high elevation situations, where the 'Map Conversion' 0.50v value should be changed from 2.90 to 2.50.
doug@frankenturbo.com's Avatar
doug@frankenturbo.com doug@frankenturbo.com is offline
whoosh
Car: Minivan, mountain bike
Default 06-25-2016, 05:24 PM
Here's a test result we did of the latest firmware's "auto calibration" feature for the 4bar TMAP sensor. The JB4's readings are overlaid with those from a standalone data logger that has a highly accurate, manually-calibrated MAP sensor.
That's some nice accuracy.
TBM TBM is offline
Car: 2007 E90 335i
Default 06-28-2016, 04:53 PM
Was talking to Terry via email earlier...
2007 E90 335i 6AT - 580whp/550wtq
Default 06-28-2016, 05:26 PM
Support requests are deleted from main forum threads. If you need our help you can continue to work with us via email or just use the support forum for public assistance.
TBM TBM is offline
Car: 2007 E90 335i
Default 06-28-2016, 05:37 PM
OK. Made a thread in public support forum and will continue communicating with you via email. Thanks.
Default 06-28-2016, 08:07 PM
Normally just one or the other to avoid wasting support time... If we're working via email we don't want to go copy the same information to the thread and vice versa.
TBM TBM is offline
Car: 2007 E90 335i
Default 08-21-2016, 01:38 AM
I remember seeing it somewhere, but can't find it now.
What's the boost scaling on fuel gauge with the 4bar?
Stock TMAP is mid(10psi), full (20psi).
XXXDrive XXXDrive is offline
Car: 2010 E92 335
Default 08-21-2016, 02:22 PM
+1 for 3.5 and 4 bar
Default 08-22-2016, 11:21 AM
The boost scaling now is set so that full is whatever your boost safety setting is. That way you know if it gets to full things are close to switching to map4.
TBM TBM is offline
Car: 2007 E90 335i
Default 08-22-2016, 11:59 AM
Which firmware revision is this change effective?
Default 08-22-2016, 06:33 PM
Don't know, would be in the firmware notes. Been that way awhile though.
pepper135i pepper135i is offline
Car: 135
Default 09-14-2016, 10:19 PM
Originally Posted by BuraQ
Its a M6x15 screw that can be picked up from any hardware store preferable Home Depot. Use the extra screw that came with the 4bar to source the length.
You will need to pick up a fatter o-ring also. The o-rings that come with the 4bar will leak since there is only one screw support for holding it on the charegpipe
This is the o-ring that will make it nice, snug, and tight without worry, just make sure to spray some WD40 on the o-ring to lubricate it.
http://www.homedepot.com/p/31-O-Ring...6745/100258186
Went to Home Depot tonight and got the supplies you recommended . Only issue was they only carried m6x16 not x15. Do you think m6x16 will work on er charge *****?
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 09-15-2016, 08:54 AM
Idk, depends on how gapped the hole threading is or if its dual tracked. Only one way to find out, if you can't screw it in with your bare hand then no.
Use judgement to know if you going to strip the hole if you force it.
2012 E89 Z4 sDrive35i M Sport MT
2011 E92 335is w/DCT
2007 E92 335i 6AT
a335i a335i is offline
Car: 2008 335i sedan
Default 12-15-2016, 08:42 PM
On the 4bar I've had a couple random reports of 2ABD faults post install. Just email me if it comes up so we can work out the details. Some of the flash maps seem to have a different TMAP voltage range saved causing the issue.
Also by popular demand we're going to start including a longer metric bolt with the kits too:
18-8 Stainless Steel Metric Pan Head Phillips, M4 Size, 14mm Length, .7mm Pitch
Terry Hello I've installed the 4bar tmap sensor in the JB4 user settings change the N20 to (2) but I've been getting codes (2ABC charging pressure sensor) and (3100 low boost mode engaged.)
Hope you can help me.
Default 12-15-2016, 08:59 PM
If you are using one of our BEF maps and have not made any changes to it, and firmware is current, then maybe a faulty sensor.
