12-02-2016, 05:43 PM
I noticed the E85 back end flash for JB4 is running 12.8 AFR up top. Is this really safe for running E40 or would you recommend running the pump flash?
I know it says E40 and up run the E85 map.. but coming from boosted PI cars, 12.8 scares me
Car: e92
12-02-2016, 05:51 PM
i hear you man, i had boosted honda and under full boost it ran low 11s, 12.8 is high in my book, all motor cars usually hit low 13s, my car hits on pump high to low 11s to low 12 on pump.
Car: 07 335i AT
12-07-2016, 09:36 AM
Our flash only e40 map targets 12.4 @ 5000, 12.2 @ 6000 and 12 at 7000. You can adjust the BMS map.
12-07-2016, 09:40 AM
Awesome - I'll adjust accordingly. Those AFRs sound much more within spec. Thank you MHD!
Car: BMW E91 LCI 335xi
12-08-2016, 01:05 AM
Is there any chance to get new Fuel (Start) tables modified to E85 BEF to tackle cold start issues?
Or has anyone good instructions and settings to modify those tables? It's getting quite cold here in Finland
335i LCI xDrive AT, JB4, ***, Stage1 LPFP, MHD E85 flash.
Car: BMW E92 N54
12-08-2016, 02:53 AM
I want to flash back to stock completely I don't have DME backup file.
I tried flash back to stock car didn't start MHD should remains installed..!
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash,  .
12-08-2016, 06:44 AM
Hello! New here.
Car: 2008 E93
12-08-2016, 09:10 AM
Originally Posted by 1inVirginiaBeach
Hello! New here. I did the MHD JB4 backend flash. I feel like my boost is very off and often just showing 3-4 psi. When I flashed it, I did 4/2 and 4/5, which I got that info from some other thread. Also saw 4/4 but the table says that is for something to do with the exhaust. Has 4/4 changed to something else? What am I doing wrong?
Mods are
********* dp
chargepipe
intake
jb4 (obviously)
Start by changing duty bias setting all to 50
Enable 6cyl timing to read timing on all cylinders.
Youre not reaching target because your duty bias settings are too low.
12-08-2016, 12:59 PM
Hello! New here.
Support requests are deleted from this thread. If you need help post a log and details in the support forum.
Car: 1998 M3 GT3582R
12-08-2016, 05:34 PM
Please help!
I attempted to do a MHD jb4 BEF for ST IJEOS pump gas. I backed up the sock map. Then I attempted flashing with the tablet in airplane mode, 12V6amp charger from HF,jb4 in map 0, me outside of the car, doors closed. I tried 3 times and never got past 3% (failure to write ECU. Falied to write packet section 113) (failure to write ECU. Falied to write packet section 536) I don't remember what the 3rd one said. I went to double check that jb4 was in map 0 but now the steering wheel menu for jb4 doesn't work nor will it connect to Bluetooth. On the final attempt I did it with the fuel pump fuse pulled however I didn't give the battery anytime to build back up if it even dropped amperage at all in the first place.
Any ideas?
Car: BMW 2009 335i xdrive
12-08-2016, 06:47 PM
Originally Posted by e36luv
Please help!
Any ideas?
All you have to do is remove the small gray subconnector from the JB4. Plug the stock ecu back in and it will then do a full write. Nothing to stress over.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
12-08-2016, 10:36 PM
Stupid question. I'm getting ready go ST in a few weeks. I'm currently running MHD and will be running JB4 Bef for my setup. Can I hook up my JB4 and run it on map 0 with the MHD till I finally start my built?
12-09-2016, 05:55 AM
Just run a JB4 bef catered to your current set up.
Car: 2008 335i sedan
Which flash to use? -
12-09-2016, 10:00 AM
Thanks for the support you bring with this page and discussions, I hope you can help me out on which flash to get for my new parts installed.
2008 BMW 335i sedan Automatic with JB4 with latest firmware and MHD App
I just added some parts to my car and do not no such map or flash use with the new parts here's the list:
4 bar TMAP
VTT turbo lite gc stock location
VTTinlets
VRSF intakes
VTT outlets
VRSF 7 inch intercooler
VRSF Charge Pipe with HKS BOV
VRSF charge pipe with hks bov
BMS methanol injection single cm 10 nozzle
Fuel- it stage 1 LPFP
Car: 335xi, 335i
12-09-2016, 01:50 PM
I'm about to try the MHD race flash for the first time but noticed in tuner pro that the timing on the BMS MHD race flash is 2 to 3 degrees less than BMS BB Flash up top. Any reason for that?
Just wondering if I copy my modified timing tables from the BMS BB flash over to MHD which are 3 to 4 degrees more up top.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Car: 2010 BMW 135i
12-09-2016, 03:50 PM
So i'm totally confused on this whole tune thing. I just bought a JB4 and I'm about to install it tomorrow. What is an MHD back end flash? How does it work? Do I just flash MHD like normal, then use the JB4 at the same time?
2010 135i . BMS DCI . Deleted Secondary Cats . Deleted Resonator . Dual Turn Downs . VRSF Chargepipe . NGK 5992 Spark Plugs. MHD Stg1+ . RCA Voyager III Tablet . 93oct+E40
12-09-2016, 03:56 PM
Search MHD JB4 flash discussion. Then download the files and flash the appropriate JB4 MHD bin file using the OBD2 port.
Just be sure to set the JB4 to Map 0 before uploading the back end flash. The initial write will take around 18 minutes so be sure to have your car connected to another running car with battery cables so the voltage doesn't drop.
It's a very easy procedure so no need to stress.
Car: 2007 335i E-92 6AT
12-09-2016, 03:58 PM
4 bar TMAP
VTTinlets
VRSF intakes
VTT outlets
Your specific DME ex. I8AOS
Single Turbo Hybrid
-Pump
-Race
-E85
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
12-10-2016, 02:09 PM
Hey guys, they posted the XDF files for the cold start tables. If anyone on E85 has a hard time with cold starts email me the BEF file you're running and I'll patch over a cold start table mod to evaluate.
Car: 08 535xi
Mhd flash and jb4 -
12-10-2016, 09:27 PM
I want to run e60 mix so I can run higher boost than 17psi how can I if I have jb4 can I use the mhd back end flash ? Will jb4 still work etc I have a walbro 450 I need to install
08 535xi mtech body kit
Mmp inlets &outlets,vrsf *********
Custom 2.5in exhaust,custom fmic
Jb4 e30 mix,3" charge pipe w/bov
12-11-2016, 04:48 PM
Single Turbo Hybrid
-Pump
-Race
-E85
Hi I tried looking what my DME is can't find it tried looking with the JB4 app under user settings read only and nothing maybe you can give me a hand
2008 335i sedan Auto
12-11-2016, 04:51 PM
Try them all. It won't let you lash the wrong one anyway.
12-11-2016, 04:58 PM
Thank you, for my setup do you think the BMS race flash would be fine:
VTT thing turbo light GC stock location
VRSF 7" Intercooler
VTT inlets and outlets
VRSF dual intakes
Upgraded PCv valve
BMS water ,-meth 10cm nozzle
VRSF *********
Upgraded oil cooler
I'll be running 93 octane+meth
12-11-2016, 05:01 PM
No. You need e85 or race gas to raise that octane up to 100.
12-11-2016, 05:02 PM
Don't rely on meth for octane.
Salo
