08335ibmw 08335ibmw is offline
Default SO JUST RACED A 335I WITH MHD STAGE 2 - 11-14-2016, 10:45 AM
AS TITLE SAYS RACED A FBO 335I , SAME EXACT MODS AS ME ONLY DIFFRENCE HE WAS ON MHD STAGE 2 TUNE WITH E30 . I HAVE THE JB4 MAP 5 WITH E30. HE PULLED ON ME BY HALF OF A CAR EVERY RUN. HE SAID HE WAS BOOSTING AROUND 17PSI I CAN ONLY GET 16ISH OUT OF MINE. IS MHD BETTER THEN JB4?!?!?
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
automech automech is offline
Car: e92 335i
Default 11-14-2016, 10:50 AM
i dont think there is a definitive answer here. jb4 was limiting your boost probably because of timing. maybe your intakes have carbon buildup, maybe your IATs were higher, maybe your ethanol blend was less than e30 maybe he was on e40. post some logs and folks will get you some answers
PawlyGuNNz PawlyGuNNz is offline
Car: 135i N54 6sp MT
Default 11-14-2016, 11:49 AM
good response... subscribed...
jb4 g5 ISO,MHD\JB4 BEF, Pure stage 2 hybrid hi flow n54,PR stage 3 fuel pumps, ADE port injection,RB PCV, BMS occ, ER CP, TIAL BOV, VRSF Hotside inlets, VRSF 7" fmic, VRSF 3" ***, n55 mid, Berk Race, NGK GTR plugs, HPF Spec smfw twin disc clutch
Default 11-14-2016, 12:59 PM
Yea my IAT were up to 155
snelson3003's Avatar
snelson3003 snelson3003 is offline
Car: 135I
Default 11-14-2016, 01:03 PM
No it is not. If you are seeking to install a tune that is set it and forget it then MHD is great.
But if you want to fine tune your driving, use the JB4 safety's, and have room for a larger turbo setup at some point JB4 will always be the way to go.
Support too.
I would tell you to do a BEF and re-race. You will pull if you stack the BMS PUMP Flash and run map 2.
498WHP / 516TQ : 10/29/16
VTT Stage 1 + Billet Wheel | VTT Inlets | VTT PCV Valve | JB4 G5 ISO | BMS E85 Flash | Fuel It Stage 2 | ECS TwinTake| Stett Vacuum Canisters | Hartge Stepped FMIC | VRSF DP | 91Oct w/E50 | BMS Cowl Filters | Located in Denver, Colorado - High Altitude!
Maintenance: EKPM3-DE @ 74K | Water pump & T-stat @ 70K | Valve Cover @ 50K | VTT Turbo @ 70K | HPFP @ 65K | Walnut Blasting @ 65K | 6 Injectors @ 55K | Vacuum lines @ 55K | Spark Plugs @ 75K | Boost Solenoid @ 65K
Default 11-14-2016, 01:24 PM
Yea im waiting on the bef . Lol got to find some one close to me
Default 11-14-2016, 01:27 PM
You'd need to datalog your car to evaluate why the tuning is doing what its doing.
Car: 135I
Default 11-14-2016, 01:33 PM
+1 and if you are hoping to use somebodys cable to flash that would be silly.
Buy a cable and download MHD, use the JB4 flasher module ($50) and flash the pump flash.
I would advise you to get the cable so you can flash yourself. I use mine often for flashes and changes to best suit my needs.
Default 11-14-2016, 01:34 PM
Think this is a run from the same day
Car: 135I
Default 11-14-2016, 01:44 PM
Looks clean for the most part.
Trims is about maxed out.
FF is maxed out but PWM is good.
LPFP starting to get a little weak but that normal on E85 mixes.
IGN is a tad high but its learning down.
Overall you are having a few slight issues but looking good.
PUMP BEF would help your trims a bit and probably make some decent power.
Default 11-14-2016, 01:55 PM
THANKS FOR THE INPUT ANY ONE HAVE A LINK OF A CABLE THAT THEY HAVE HAD SUCCESS WITH? I ALREADY GOT THE MHD APP JUST GOT TO GET THE CORD AND BUY THE LICENCE THING
Default 11-14-2016, 02:02 PM
Log looks decent. It's not particularly aggressive. I see you are working up against a DME fueling limit so adding in the free or MHD back end flash map would open up your power. If you run E30 normally RACE is a good way to go. Can be used on pump fuel and various E85 mixtures.
Car: 135I
Default 11-14-2016, 02:47 PM
http://bimmersoftware.com/Cables
I have this one and it works great. Use it once a week and keep it in my trunk in case i need it for something.
Default 11-14-2016, 03:08 PM
Default 11-14-2016, 03:45 PM
The otg Cable makes it hook to your phone? I don't have laptop only Android (s6)
E92Beast E92Beast is offline
Car: 09 E92 335i AT
Default 11-14-2016, 04:33 PM
U can't use a laptop get cable, otg to usb that fits galaxy s6
09 E92 335i Msport, fbo+e85 flash, 11.91 @ 119
10 E90 335i, MHD Stage 1
klipseracer klipseracer is offline
Default 11-14-2016, 04:35 PM
As others have stated, its impossible to say which tune is better based off of this due to so many other factors. Even when both tunes are exactly the same, I'd be willing to bet there are other variables like the miles on your cars that would make some kind of impact on the race. Even the state of your transmission, post shift timing, etc.
Car: 135I
Default 11-14-2016, 04:42 PM
Yes I would shift before 6krpm too keep your car in its power band. I have upgraded turbos but still shift before redline to maintain my higher boost.
But like for like, racing in the same are at same time, you'd still lose. MHD is relatively aggressive for a tune in general but JB4 + BEF would meet your need to beat him.
Default 11-14-2016, 05:20 PM
How much e85 should i run once I have the bef.. I only used 4 gallons of e85. I thought that was e40 lmao but I misread the info I was using ...
I have stock lpfp and will upgrade soon
Default 11-14-2016, 05:27 PM
Yea his car was a 09 and had 85k miles mines a 08 with 98k Walnut blasting 7k miles ago
He was on stock tires as well
Vanbibbs33 Vanbibbs33 is offline
Car: 135i Vert 6MT
Default 11-14-2016, 06:19 PM
That mixture is only about E25 maybe even lower. Once you do the BEF go to E50. It might seem like a lot but in your tank that's around 8 gallons of E85 and 7 of 91. Use this calculator and account for E85 to really be E70 or lower. I think some guys have tested pumps and found bare minimums(E51) so be careful.
I run slightly under E50 and I've had boost levels around 19psi without the BEF. I think just simply upping your mixture will give you the edge. You'll want to do the inline pump or maybe even the stage 2 if you plan on using E85 regularly. I have a station .3 miles from home so I practically drink the stuff
2010 135i Cab 6mt Montego Blue MSport JB4 G5 - Fuel-It stage 1 - VRSF DP -ARM chargepipe with Tial BOV - VRSF 5" stepped FMIC - MMPE stock location Inlets - MHD
Default 11-15-2016, 05:24 AM
Good to know
Default 11-15-2016, 12:25 PM
I normally run 93 with no e85
