(#476)
Poppowisch's Avatar
Poppowisch Poppowisch is offline
Car: BMW e93 335i
Default 04-19-2016, 09:43 AM
"noob question"
Is it more safe for the gearbox to go whit the alpina flash on a JB4 tuned car? Does Alpina handle more hp and tq better then the stock flash?
BMW 335i e93 M-sport 2007 AT Alpina B3 TCU, JB4 G5 whit MHD BMS backend flash pump
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 04-19-2016, 02:11 PM
I believe the alpina flash handles the extra power and torque better
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
MarcN54 MarcN54 is offline
Car: E90 335XI N54 2010
Default 05-23-2016, 09:16 AM
Hi there,
First i have to apologize for my english :|
Hopefully you can understand my following Description.
I had flashed the origin B3 Soft on my 2009 N54 335xi (ZF 6HP19TU).
Cleared Adaptions and drove about 1000 Miles.
Since the beginning of the Flash i had Problems when take of from a Full stop in D with around 30-50% Throttle.
The transmission them don't Switch Gears in fully, nearly like a CVT.
Feels like its trying to Switch next gear and it Happens nearlY but Not Fully.
Happens from Frist to 4th or 5th gear.
If i Try less or more Throttle everything is okay.
In S and M no Problems too.
Then flashed back to stock Software 1492.
No Problems with this.
Tried Both Alpina Softwares, Both Sucks.
Oil and Filter are Brand new (Original ZF Oil and pan).
With Stock Software no Problems.
Anyone has an idea?
Default 05-30-2016, 12:23 PM
Nobody?
Caused because i have to perform the full adaption as ZF manual on page 43 says?
trebila's Avatar
trebila trebila is offline
Default 05-30-2016, 12:36 PM
http://www.n54tech.com/forums/showthread.php?t=39901
maybe ...
which back end flash are you using ?
Default 05-31-2016, 04:16 AM
Thx Trebila.
Engine completly stock. 80k Miles on it.
Just performance exhaust and power kit (326hp) installed by BMW Dealer around 25k Miles. DP's stock too.
trebila's Avatar
Default 06-17-2016, 04:24 AM
Originally Posted by J. Dub
Trebila, are you the only one that can fix the alpina regular D mode transmission shift points?
Currently my alpina flashed 6AT, when cruising around town, will shift around 1600rpms. Are you able to change those shift points to 2000rpms for every gear?
Here are 2 vidoes to show you how AT with alpina trans flash upshift at really light throttle, with my DME flash.
You won't get this with the obsoletes tables published a year or 2 ago :
in D mode:
in S mode:
JackBurton JackBurton is offline
JackBurton
Car: 08 E92 335xi
Default 07-02-2016, 07:01 AM
Read the DIY about loading the Alpina B3 trans flash using WinKFP. Is it possible to flash the B3 using the MHD flasher? If so is the process the same as loading a custom map?
DaZuc DaZuc is offline
Car: 335i xDrive
Default 07-02-2016, 09:00 AM
No, all MHD does is when you're flashing a map it asks you which transmission you have.
Manual
DCT
Auto
Auto w/ Alpina Flash.
Default 08-24-2016, 07:53 AM
Hi there,
does anyone still have the Alpina B3(S) .bin anywhere?
IJE0S or Europe Version will be fine.
Link in the Download Section on bxxxxboost is down or files deleted
Thank you!
Marc
chatz86's Avatar
Default 08-24-2016, 07:55 AM
It isn't a. Bin... Its a process
Default 08-24-2016, 09:41 AM
Need the origin .bin from the alpina b3 flash.
Want to copy the load targets and breakpoints out...
http://www.boostaddict.com/showthrea...3S-Biturbo-bin
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 08-24-2016, 01:56 PM
PM me your email address. I have it.
Banana Clipper's Avatar
Banana Clipper Banana Clipper is offline
Car: 09 335i
Default 08-24-2016, 02:08 PM
in D mode:
in S mode:
Where can I purchase this trans flash? NOT the Alpina, I want the trebila custom one
trebila's Avatar
Default 08-24-2016, 03:26 PM
This is a DME flash working in cunjunction with the alpina trans flash.
Send me a PM
Car: 09 335i
Default 08-24-2016, 03:37 PM
Send me a PM
pm'd ty
Unklejoe Unklejoe is offline
Car: 2011 335i
Default 09-01-2016, 04:59 PM
Anyone seen this?
https://www.vrtuned.com/transmission...bmw-gs19-gs20/
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 09-01-2016, 06:35 PM
Interesting. Thanks for finding. I'd like to learn more. I see Vivid Racing is located in Arizona in the Phoenix area. I wonder if @SteveAZ knows anything about them!
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 09-02-2016, 12:48 PM
Hey there, I had/have the Alpina trans flash installed a few years ago. I had to replace my DME recently. Do I still have the Alpina flash ? Does it live in the DME, or in the trans itself?
Will I have to reflash it? Thanks! Larry
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
trebila's Avatar
Default 09-02-2016, 03:40 PM
it's stored in the TCU, so you still have it.
Zoki Zoki is offline
Car: 335i E92 N54
Default 10-18-2016, 10:28 AM
Hi there,
Anyone has an idea?
Were you able to sort this out, I'm getting the same issue.
mp335 mp335 is offline
Car: 09 335i
Default 12-24-2017, 03:06 PM
Hope you experts and trebila can help to answer my questions.
I have 07/09 e90 335i AT with power goals of ~480wtq.
a) Does my year model has different transmission than earlier models ? hp21 vs 19TU?
b)Does tcu flash really help to prolong trans life? or can actually negatively impact it?
b) alpine vs xHp, which one you would recommend?
Car: 09 335i
Default 12-27-2017, 12:12 PM
anyone please?
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 12-28-2017, 03:20 AM
Alpina
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Car: 09 335i
Default 12-28-2017, 03:18 PM
Originally Posted by K.Jameel
Alpina
thanks which number? looks like there are 2, my car is 2009 not sure which one I can use. Also does anyone figured out D mode fix ?
