09-10-2015, 09:52 AM
All it takes is for somone to try to clear this issue up. I'm more than happy with mine now it's modded so I don't wish to try  Although after welding out the squashed sections of my RHD 335i rear turbo outlet pipe I am 99% certain no other pipe wil fit. The Space left now is seriously minimal. The RHD pipe almost touches the manifold without welding out the squashed point and as for the steering column side there's only a few mm's left after I Modded it. I will try to get some decent pics of how it looks when I get home from offshore in a week or so.
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: '10 335i
09-13-2015, 01:32 AM
Put me on the list, my wife loathes these forums hahah.
Car: BMW 135I
09-13-2015, 08:07 AM
Rob,can you put me in also .
Stalker
Car: 335I
09-13-2015, 08:09 AM
Introductory cost will be $189 plus shipping and come with 3 SS T-Bolt Clamps.
List:
1) FRNTHVY
2) Flatspot
3) shandyb135i
4) brendan
5) cebrailbakan
6) Dvo0208
7) 335xiboost
8) cbmac412
9) E92 420
10) ross22
11) _ink
12) triggz
13) Fast335i
14) kenjermen
15) dlp3719
16) Nexic
17) Race8877
18) cya
19)
20)
5 series list:
1) JWMich
2) Nyulak
Car: AW135/E30M3 Junglegym
09-13-2015, 09:26 AM
Do you have an anticipated ship date?
Stalker
Car: 335I
09-13-2015, 10:10 AM
It would take about 3-4 weeks after we place the order and numerous things have yet to be done before the order can be placed. So probably around 30-45 days.
Thanks,
Rob
Car: BMW 535xi
09-14-2015, 06:35 AM
Please add me to the 5-series list.
Stalker
Car: 335I
09-14-2015, 07:56 AM
Done.
09-14-2015, 11:34 AM
Originally Posted by Nexic
From the pictures, it looks like we will need to cut our existing hot side tubing to fit into the silicone, correct? Or will this be one whole silicone piece from the hot side to FMIC?
Have you read the thread or just looked at the pictures
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: '10 335i
09-14-2015, 12:02 PM
It says minor fab work, I would say its a little more than minor. Either way, I just purchased a used OEM hot side piping for the 335i off ebay for $60 to fab up for this. That way I can retain my OEM parts.
Stalker
Car: 335I
09-14-2015, 12:12 PM
Sorry about that. Will change "minor" to "moderate" fab work. I'd rather error on the side of caution if not anything else.
Thanks,
Rob
Car: 2007 BMW 335i
09-21-2015, 09:53 AM
Any closer to hitting go on this deal?
Stalker
Car: 335I
09-21-2015, 10:32 AM
No sir. Have silicone vendor loaded through the roof. Kind of trying to keep them focused on one/two/three things at this time to keep from overwhelming...
Car: E92 335i
09-26-2015, 04:53 AM
Any progress re the HSCP build Rob??
Stalker
Car: 335I
09-26-2015, 09:17 AM
None unfortunately and I'd say this one is getting put back quite a ways. Not for any other reason than we need our silicone vendor on more pressing things at the moment… just a guess I'd say sometime in November.
Rob
10-06-2015, 09:19 PM
Please add me to the list. Thanks.
10-06-2015, 11:43 PM
Update: Sample is in hand. This week we will be test fitting it and if all seems well we will look into producing it.
Lets make a preliminary list to see if there is any interest? Introductory cost will be $189 plus shipping and come with 3 SS T-Bolt Clamps.
Hi Rob
Can you please explain how this RB high flow kit connects to the IC´er? Right now there is the snap function and I assume that your piping do not have this connection, or will this connection be a possible add on made by you like the high flow oil return lines.
Thanks for clarifying
Best
Stalker
Car: 335I
10-07-2015, 05:32 AM
Originally Posted by jacobniell
Hi Rob
Best
Jacob,
This may not work for everyone and every style of intercooler. Our immediate plan is to offer a couple versions pending on IC style (to cover the vast majority of possibilities), but connecting to the OEM IC (or the HPF with similar clamp) is bar none the lowest priority. If we ever do get to that point we will probably have to CNC an adapter to meet said interface, and then allow the hose to slip over said adapter. All kind of a useless pain simply to retain that clip.
We will have to cross the bridges when we get to them. As of this moment we have our vendor so backed up this project in its entirety is very low priority at this moment and probably will remain low priority until late November.
Thanks,
Rob
Car: 09 E92 SG
10-07-2015, 02:25 PM
Rob, I have an AWD coupe. Can this be installed without dropping the subframe?
Stalker
Car: 335I
10-07-2015, 02:30 PM
Should be as long as you can access the v-band clamps to remove your hot side charge pipe.
Rob
Car: 2008 BMW 335i
10-07-2015, 07:33 PM
Im in
Can you put me on the list.
Car: 2010 535i 2002 530i
10-13-2015, 10:51 AM
Rob
Rob please add me to the E60 list. Thanks.
Stalker
Car: 335I
10-13-2015, 10:58 AM
Update: We are going to go ahead and order 20 or so of these. Hopefully some of you guys really want them! A couple pics have been attached.
List:
1) FRNTHVY
2) Flatspot
3) shandyb135i
4) brendan
5) cebrailbakan
6) Dvo0208
7) 335xiboost
8) cbmac412
9) E92 420
10) ross22
11) _ink
12) triggz
13) Fast335i
14) kenjermen
15) dlp3719
16) cmiggz
17)
18)
19)
20)
5 series list:
1) JWMich
2) nitemare
3) Younge60
Car: 2008 535i
10-14-2015, 12:29 AM
Count me in on the 5 series list Rob!
2008 535i E60
Custom stage 3 lpfp 100% e85
Fuel it port injection
M5 rear end and driveshaft
6AT --> 6MT
PT 6466
Car: 2008 BMW 335i
10-14-2015, 11:27 AM
Rob are you going to order these asap?
When do we send payment?
