ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 08-28-2015, 08:31 AM
Originally Posted by Spxxx
Until the diff explodes haha.
This!
Nice work Spencer. Great to see it put down big numbers AND perform at the track. Were any settings or adjustments made specific for the track or was it simply: brake boost and smash the gas?
Evan
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes, M5 Rear Suspension
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Trans Swap, MFactory SMFW, Spec Stg 3+ Clutch, UUC SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor
- JB4, Hexon RR550s, Custom Inlets, AR ***, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB Ext. PCV, BMS OCC
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default 08-28-2015, 10:02 AM
Originally Posted by ucsbwsr
This!
Evan
Pretty sure just brake boost and go, it was his first time at the drags and only got 2 runs in. His tune is also pretty much just a base map as we only made one revision, his logs looked good though. This is the same map he dyno'ed.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 08-28-2015, 11:44 AM
I have a Google Galaxy nexus phone that I used for MHD for sale. Lmk if you want it.
Doh!
I just ordered an HP Slate 7 Extreme. (And the OTG cable)
Bluetooth & OTG will make it a good dedicated tablet.
Will only be missing the LTE Data.
I'll leave it mounted in the car and no longer use my iPad for JB4 Mobile.
Hate having to take the iPad Mini in and out of its case constantly.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Default 08-28-2015, 04:27 PM
Did someone say front diff? Lol
knissel's Avatar
knissel knissel is offline
Car: 08 335xi
Default 08-28-2015, 05:12 PM
Pic didn't load for me. What is going on with your car btw jw
E85 Calculator for Mobile Android iPhone
11.762 @ 118.40 (335xi Stock Turbo WR)(Totalled)
09 335i xDrive Stock (Sold)
12 GT-R BE 800 awhp 9.8 @ 139
Default 08-28-2015, 06:37 PM
Haha- the pic was about 2-3 pieces of my front diff
Car is back up and running- hoping to hit the track soon (maybe this weekend...)
antoniogaj antoniogaj is offline
Car: 2010 335i xDrive
Default 08-28-2015, 09:52 PM
How much did that run you? Assuming mine will do the same eventually
brnmcn brnmcn is offline
Default 08-31-2015, 10:52 AM
Not sure what you mean
How would I use your flashes stacked with a JB4 G5 firmware 31?
I flashed a custom map in MHD with the Mboost option and kept the jb4 in map 0 because I didn't want to screw anything up.
Per Terry's post http://www.n54tech.com/forums/showpo...10&postcount=1, I should be using map 1.
Are you doing something different?
jlcf22 jlcf22 is offline
Default 08-31-2015, 11:35 AM
was this done with the stock tmap sensor or the n20?
Spxxx's Avatar
Car: E92 335i
Default 08-31-2015, 11:57 AM
Load it with JB4 in map 0 and then AFTER loading the MHD switch the JB4 to whatever map you want to run AND set your steering wheel setting to 4-2 & go rip.
guru_method guru_method is offline
Car: 09 AW 135i
Default 09-02-2015, 12:14 AM
Originally Posted by Texsquirrel
Doh!
Good call on the Slate, best deal around for sure.
Make sure to adjust the settings to the highest performance when using it on the car. Had a minor lagging issue at regular setting.
Car: 2009 BMW 135i
Default 09-02-2015, 12:38 PM
Ok, I'll have to figure out how to do that.
Still learning the Android.
Only had Apple iPhone and iPad so far.
So far I like the Slate.
Just bought JB4 Mobile (again) and downloaded MHD.
E90Convert E90Convert is offline
Car: 08 E90 335i
Default 09-02-2015, 02:17 PM
Wow nice run
E90 335i 6-Speed Manual
JB4 ISO G5 - BMS Pump flash - VRSF Inlets - VRSF FMIC - VRSF CP - HKS BOV - VRSF DP's - Dinan oil cooler - BMS OCC - H&R sways - Goodridge Stainless lines - ATE slotted rotors - Hawk HPS/R Pads - Apex Arc-8 17x9
omarmarji's Avatar
omarmarji omarmarji is offline
Car: n54 335
Default 09-02-2015, 08:27 PM
so basically we use this as a back end flash? also can I run 100% e85 with this?
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
CURRENT: E82 135i (under construction)
Visit my website VaderSolution.com !
Spxxx's Avatar
Car: E92 335i
Default 09-02-2015, 08:33 PM
These files are just starting points, load the correct one up, take logs and email me them to me, I can then make slight changes to make sure it's running well for your conditions. I can modify the map to run pure e85 but for now I'm just going to leave the current maps up.
Shoot me an email at spxtuning@gmail
cbrvnm's Avatar
cbrvnm cbrvnm is offline
Car: 07 335i
Default 08-04-2016, 10:11 PM
I would like to know if I could run your e60 map on a 07 335i full-bolt on with hexon rr600 turbos with stage II boost concepts fuel pump, 3.5 bar TMAP, and inlets/outlets safely? I have JB4 with backend flash with MHD (just recently flashed hybrid E85 mix backend) and wanted to try out some other maps. I know I need a custom tune, but came across this thread and saw results with stock turbos and wanted to give it a try. I think that if the ethanol calculator that I used is correct, I currently have e60 fuel (10 gal of e85/5 gal of 93 oct). Thanks.
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 08-05-2016, 06:08 AM
Originally Posted by musc
Should be one of these hitting the track in the next few months.
I will try for 10.xxx.
Dyno monday after that....track
At 27-28 psi on ms109...I will be close to 10
Fbo
Rr600
Inlets
Fuel pump
Meth
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
