(#126)
knissel's Avatar
knissel knissel is offline
Car: 08 335xi
Default 06-03-2015, 04:41 AM
Sorry if posting that pic was stupid I just thought it was a good diagram.
http://www.plex-tuning.com/products/...nitor-v2-0-new
^Maybe this is useful though but I doubt would be any better than DME
E85 Calculator for Mobile Android iPhone
11.762 @ 118.40 (335xi Stock Turbo WR)(Totalled)
09 335i xDrive Stock (Sold)
12 GT-R BE 800 awhp 9.8 @ 139
nyt nyt is online now
Car: 335ix
Default 06-07-2015, 06:33 PM
Originally Posted by jyamona
Ok I will hunt them down when I get a chance this week.
That is fine, just keep them together and at the top of threads, etc. Using the most up to date from the repo will always work with your latest bins as well
Any word on getting those other tables mapped? I have a stock turbo car running straight E85 and meth. The current table changes have made a good deal of progress, but I still see small timing pulls every now and then. I'd like to do some further experimentation with this.
Bullitt1841's Avatar
Default 06-08-2015, 07:48 PM
I was serious about it being a great find. Great visualization for how a knock sensor differentiates between each cylinder.
I was mostly poking fun at how Terry didn't think it was high tech enough. I guess he has faith in the DME!
Default 06-08-2015, 08:49 PM
Heh J&S is pretty old school. Back when it came out it was cutting edge. But much less advanced than our DME's integrated system.
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 06-08-2015, 08:52 PM
only 900 euros (over 1000us)
Daily: G30 M550i JB4
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPPK front & 50i rear brakes, M50d grill and trim
Gone: E92 N54 468wtq
Kommodore Kommodore is offline
Default 06-08-2015, 09:53 PM
I always thought to myself that if I ever ended up owning an S38 car I'd have a Vampire system for it installed.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 06-24-2015, 04:40 AM
Originally Posted by PR3CI5N335i
Loaded up a new MHD E85 IJEOS file last night from Terry and my timing drops are finally gone. I've had these issues for over a year now and I feel like my car has been running at 85% of its power potential due to these timing drops but not anymore. Thanks for the hard work guys!
Map 3 75add, E60, 100% Meth, AT, stock turbo's (for now)
Can you post up any before and after logs?
On my car with 60% meth, 40% water and 15% E (UK based, no E85 available) I seem to get great timing on all but cylinder 2. Just wondering if it's false knock. NGK 0.56mm gapped Plugs are less than 100 miles old and coil pack is brand new.
Meth addr 65, E85 flash. DCT transmission.
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
AWSAWS's Avatar
Default 06-24-2015, 04:47 AM
Hi guys,
do we just have 2 knock detectors? How do we get detection on all cylinders?
I was reading this article. I take it the N54 doesn't use the spark plugs as ion detectors for knock?
http://www.bimmerboost.com/showthrea...ually-happened
I have been on other threads about indexing plugs. I read this an thought, OMG, are my none OEM NGK plugs being used for knock detection???
Does this method then get used in the M3/M4 making tuning more challenging?
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 06-24-2015, 06:53 AM
Originally Posted by AWSAWS
Hi guys,
It is one knock sensor per bank, then a time measurement window is applied in the DME for the knock sensors to listen for noise from a particular cylinder. The time window is based on firing order, giving an easy way to detect per cylinder knock.
AWSAWS's Avatar
Default 06-24-2015, 07:23 AM
After seeing the earlier diagram I should have put 2 and 2 together. Thanks!
The Leopard's Avatar
The Leopard The Leopard is offline
Car: E92
Default 07-03-2015, 07:00 PM
Terry, have you been able to get the built motor's timing corrections to go away with these tables?
I'm thinking of going built bottom end, but not at the expense of inconsistent timing.
TS N54
Default 07-03-2015, 09:35 PM
No it's been out of commission for the last few weeks. We took it apart to make a new intake or mount our single filter and gave up. Just no space with the FFTEC bottom mount kit. But in the process had to pull the water pump, etc, and haven't had the time to put it back together. I'm looking forward to testing it soon though.
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 07-04-2015, 08:05 AM
Has anyone defined these tables for ILAOS_IS xdf?
335is DCT
Default 07-04-2015, 08:55 AM
We have them in INA0S. Just switch to MHD to load it.
musc's Avatar
Car: 335is DCT
Default 07-04-2015, 08:58 AM
I haven't made that leap yet. Most the 335is people I know on flash only are still on Cobb. I've been trying to get a hold of a INA0S_IS bin file so I can play around with it in TunerPro.
335is DCT
Default 07-04-2015, 11:34 AM
If it's already at that point, might as well make it a VM kit LOL!
Default 07-04-2015, 11:46 AM
Oh if flash only who knows. We only do JB4 + back end maps around here. With MHD you don't have the torque limiter in place, which is good for the DCT trans. It's well worth the $80 entry fee IMHO.
musc's Avatar
Car: 335is DCT
Default 07-04-2015, 02:27 PM
No 18.5psi cap or torque limits on Cobb with ILA0S_IS. Been enjoying this before MHD even existed
I8A0S and IJE0S benefited the most from MHD. The only advantage I see on the 'is' rom is access to the knock table and I am not convinced I should be touching those just yet
335is DCT
musc's Avatar
Car: 335is DCT
Default 07-05-2015, 05:02 PM
ILA0S_IS knock tables defined. Guess it is time to experiment.
Terry, how far have you increased these values? I see on the E85 flash you have them maxed at 3. Did you ever try higher than that? Have you pushed the other table values higher/lower than whats in your E85 flash?
335is DCT
Default 07-05-2015, 08:49 PM
There are two other tables that act as master limits. So I'd just run the values in our back end flash map. The values we run max out the individual tables and in essence run at the master tables.
The thing is without MHD you'll be capped at stock torque ceiling. For anyone with a DCT I'd suggest spending the $80. It's well worth it.
Car: 2010 135i 6MT
Default 07-06-2015, 06:57 AM
Think it's worth me spending the time to define these master tables? Would there be a benefit in raising them?
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 07-06-2015, 07:19 AM
They're defined in Terry's XDF, so it shouldn't be a big deal for you to add them the the open source version.
Car: 2010 135i 6MT
Default 07-06-2015, 07:26 AM
No they're not. He's talking about two different tables here. You're thinking of Max vs Temps and Intensity 1 and 2. There are two more I didn't get around to finding yet.
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 07-06-2015, 01:12 PM
Seriously cannot wait to get the shop car back on the road so we can try these.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Default 07-06-2015, 01:32 PM
It can't hurt. At some point we'll go too far and start blowing stuff up. But, my gut feeling is we could probably push it a bit further on straight E85.
