(#126)
Default 07-22-2014, 03:02 PM
You can use interface on G4 boards. On 32bit I'd have to look in to it.
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 07-22-2014, 11:40 PM
Do we load the new firmware hex 28 on the g4 or leave the old firmware on and just input the dme type under the cps 7000 value?
|RB old gen|Jb4 G5|3" DP's|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
wlf wlf is offline
Car: 2007 e92 335
Default 07-23-2014, 08:00 AM
Were you guys able to figure why cylinder 5 always has noise?
i changed spark plugs,swapped ignition coils and im still having timing drops on that cylinder ( no correction though).
trebila's Avatar
trebila trebila is offline
Default 07-23-2014, 08:25 AM
the same for me, cyl 5 is the noisest.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 07-23-2014, 08:44 AM
Some cylinders tend to run hotter in certain engines. Since #5 is the middle cylinder of the rearmost bank it wouldn't surprise me if it ran hottest of all 6. Depends how the cooling channels are set up. Miata's always had the problem of #4 running hot for example. Completely different engine though so I might be wrong.
Default 07-23-2014, 08:47 AM
These features are not G4 compatible.
PWRandTQ PWRandTQ is offline
Default 07-23-2014, 08:48 AM
Hey Terry!!!
Are you ever going to do a ISO for RB cars?
Id like Map7 to run 20psi...........just wondering.
Default 07-23-2014, 08:54 AM
For the N54s map 3 w/ a 80 additive maxes out RB turbos.
michalez michalez is offline
Car: bmw e92
Default 05-29-2015, 01:20 AM
Guys im blind. I cant find CPS_7000 option to change it. Where i can find it?
AWil335i's Avatar
AWil335i AWil335i is offline
Car: 2007 335i
Default 05-29-2015, 07:29 AM
Interface has changed. Check instructions in the appropriate thread.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Default 05-29-2015, 08:07 AM
It's called 6-cyl timing now.
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 05-11-2016, 09:28 PM
When I was setting up the JB4 mobile app I was advised to enter either 4 or 5 in order to get timing reading from all 6 cylinder. Neither worked. I get all 6 when I enter 6. Why is that? How do I find which file I have. Most common are I8AOS for <2008 and IJE0S for >2008. Mine is March 18, 2008. I want to figure this out before I attempt backend flash.
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 05-31-2019, 12:50 AM
I know I'm bumping an old thread but does anyone know what value to use for an IKM0S DME? (1M)
I can't seem to log cylinders 2-6.
codesx's Avatar
codesx codesx is offline
Default 05-31-2019, 09:55 AM
Old Thread, but interesting topic.
I believe Coolant flows from Driver side to Passenger of block, not end to end.
I suspect that Cyl 5 is closest to the heat output of the turbos. That's a theory I haven't dug into (I know it's close).
I too have noticed Cyl 5 being noisier, though not as much as issue as supporting mods are applied.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
